Mzp
Hi Einar,
I do get about 700 megabytes (MB) per second transfer speed from the drone to my pcie 3.0 nvme SSD,
it might be you are transferring really large files onto your SSD, i.e. ProRes files, and your SSD (guess you are transferring onto an SSD) uses up all the fast cache and end up writing directly onto slow (NAND I think it's called) chips that could go as slow as 25MB / sec. You can try copying the file from your SSD onto your SSD (of the same size) and see if you notice speed degradation there also, if you do, most likely it's your SSD running out of cache when you are transferring files from your drone. Hope this helps.
Thanks, Mike. |
