Kepnik
Austria
Kepnik Posted at 2-23 00:45
I have the same issue sadly, I cant get them to fit without massive distortions and blurry edges... and I already expected that, didnt think it is a big issue to have blurry adges for the bigger fov... but for me its impossible to wear them, makes my head spin after 10 minutes. Also the system to find the correct ipd is a mess, to move every lens seperate ? with no adjustment counter ? I know my ipd (60) but its impossible to find it perfectly on this device :-/
Does anyone meanwhile have found a fix for them ? I will try maybe another padding, but I think I will have to return them.
So my friends, after another weekend and some playing with the goggles, the tide has turned for me.
I can state 3 things :
1.) the optics are really bad in comparison to oculus or meta quest... its just amazing that still such lenses are built, bin as far as I know in FPV there is nothing comparable to a quest 3 or even quest 1.
2.) the problem of the goggles 2 is the tiny tiny sweet spot, when you are able to hit it, the optics are great and you can use at least 95% of the 51 degrees sharp with amazing quality. It helps A LOT if you are able to get closer to the lenses. Without the face mask I have a perfect sharp rectangle with no vignette. I will build my own face mask
3.)
Additionally the goggles look very bad in the menu, dont know why, when you are flying, it gets a LOT better
So I am happy now, I accepted and also knew when buying that the fpv goggles cant compare to what VR goggles nowadays can do... but it is still an amazing way of flying. |
