Hello, I have a drone DJI Mavic Air 1. The drone has not fallen or been hit. Every time I fly I have 10+ satellites I lose gps signal. i can upload log files.
Hello there fluidmind. I am sorry for the trouble this has caused and thank you for reaching out. May we please know if you are receiving any error message on the DJI Go 4 application when this is happening and may we please know what is the model of the mobile device that you are using as well for us to be able to isolate the issue? Thank you.
DJI Stephen Posted at 9-9 19:41
Hello, the phone is not the problem (android). No errors.
the gps signal is weak only in fcc mode, there is no problem in ce.
Have you hacked the drone to get FCC Mode?
If so, that's the problem.
The solution .... just fly in CE Mode.
Labroides Posted at 9-25 03:51
Yes, i use fake gps method.
i think it works fine on 5.8ghz.
if i modify the controller with stronger antennas will that help the range or am i software limited...
can you tell me more why this problem occurs? i have a friend with the same dji mavic air 1 as mine and he has no problem?
fluidmind Posted at 9-25 05:25
I don't have any detailed knowledge about it.
I just told you what was obvious.
