JJB*
Flight distance : 12225059 ft
DJI Stephen Posted at 9-9 20:02
Hello there PCK55. Good day and thank you for reaching out. Just a reminder that when flying above the water, the vision positioning function will turn off automatically and only the GPS and barometer are used for positioning, if affected by the accuracy range, and an accident might happen. In addition I will also post a DJI Forum thread on How to Fly Safely Over Water. Thank you.
https://forum.dji.com/forum.php?mod=viewthread&tid=181878
Hi Stephen,
Can you explain why you reply is so wrong ??
First : updating HomePoint in flight has nothing to do with flying over water !!
Second ; your link informs the readers that you can disable the Vision Position !!
You cannot disable this system in the FlyApp !!
Plus the rest of your text is wrong too. Flying over water will not automatically the vison system,GPS and barometer are not affected due to the fact flying over water.....
So an accident might happen is nonsense.
Only flyiing low over water can have some issues for the bottom vision height sensor.
Please ; do change this automatic reply for something better!!
cheers
JJB
