Dirty Bird
Flight distance : 11498025 ft
Drohnenfieber Posted at 9-10 06:27
Having the same question. With DJI Assistant I can see all the logs, even after factory reset. I also see the logs from the factory (test flights as it seems). How to delete?
As Labroides said, the logs are there but they are encrypted & can't be viewed without the cipher. The internal flight logs are like the black box on an aircraft. If people could simply delete the logs at will it would defeat the purpose. |
