RachelGomez
India
The most common causes for a bad FPV video feed are caused by electrical and/or mechanical disruptions in the quad. This can vary from electrical noise coming from the ESCs, to vibrations from a bent prop. Also, objects that are in the way of the line of sight between your goggles and video transmitter can cause multi-pathing, resulting in a low-quality video signal.
There are two main types of FPV static. There is white line static, and black line static. White line static is electrical interference, whereas black line static is usually due to a lack of power going to your camera and/or video transmitter. Reboot to fix this issue.
Regards,
Rachel Gomez |
