Hi. Same place, same rate (4k/60), same shutter, etc. Why does Normal (rigth/down) have much more detail?
Another case Normal (right/down), zoom 400%:
NOTE: I do know that d-cinelike is a profile captures a broad range of colors and is not quite as flat as other neutral color profiles, but it will still need to be color graded for the best results. That's not the problem here, grade it, do whatever you like, but the d-cinelike capture footage has much less detail. Is there some kind of bug, or setting I'm missing?
