hallmark007
Flight distance : 9827923 ft
gnirtS Posted at 9-12 02:33
No cover. No warranty either.
I bought a replacement battery on a holiday in Asia which subsequently swelled up and died. Replacement refused as im registered in Europe with the drone and battery was bough outside there.
Thats not strictly true. Your warranty is only exercised in the region you purchased the drone, so if you can return the drone to the region you purchased, the warranty will cover for manufacturing faults. Care refresh is exactly the same you must return at your own expense to the region you purchased the care refresh. If it was any different then care refresh or warranty would not be covered if you traveled outside your region of purchase. |
