djiuser_DlgIHiCE2wJD
India
DJI Paladin Posted at 2022-9-11 18:40
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please try to perform the said feature and have a test flight to a different location that is not a restricted zone and check if the issue persists? Please note that we cannot perform the said feature when inside a restricted area. In addition, as for the subject scanning function, the aircraft needs to be in the take-off status to turn on this function (the function cannot be used even if start the motor only). The subject scanning function is only supported in a single shot (photo mode) and normal recording mode (normal video mode), other modes are not supported, so it is recommended to try it in single shot and normal recording mode. Hope this helps. Thank you for your valued support.
Tried but still not working |
