CloudVisual
Flight distance : 25957795 ft
SamAdie Posted at 9-14 02:20
Thank you for responding. Yes, I am using the supplied USB-C charger that plugs into the drone. That is my concern with the time it takes to charge. I thought an hour or so would be good for the battery performance you get but not well over 15 hours and into 18 hours. Really want to keep this thing but looks like I'll be sending it back if mine isn't acting normal to most others out there.
"Yes, I am using the supplied USB-C charger that plugs into the drone"
There's your issue. Don't charge the battery in the drone, that's what the multi battery holder brick is for. You can charge it in the drone, but you won't get the full speed. |
