Booradley
Flight distance : 11349537 ft
Hi CaveDrone,
Yes I was addressing your original question, thank you for responding.
Just a footnote before I get into my response, I have had one incident with my drone near high tension power lines, the kind with exposed coils. I posted the video on YouTube to help others avoid my mistake. Luckily for me, my drone was not damaged in this incident however, I have gotten quite a debate going about whether the power lines played a roll or not.
The power lines you mentioned, were they heavy duty? The kind that are exposed to the elements, that have coils, and birds do not land on? Sometimes referred to as high tension power lines? I have heard that these types of power line will actually light a fluorescent bulb if you get it close enough to them. Either way, I feel like and agree with the instructions to be extremely cautious near power lines. I am a prudent flyer and believed the 150+ yards away was good enough to fly. What happened was, anytime I was within 50 feet of the ground (and it seemed to get worse as I got closer to the ground) the drone would take on a mind of it's own. I'd be solely ascending or descending only to have the drone move forward, back and side to side... I've tried everything in the book to validate it was the power lines. IMU calibration, compass calibration, and a remote calibration. I have tried it with VPS on and off. I also calibrate the compass before every single flight and do not fly until I hear "home point has been updated." I invested too much in this drone to take a chance. I have flown the drone in many other locations, including near residential type power lines (the kind that are not too high off the ground and are insulated. Birds love to hang out on them). I have not had the issue at any other location other than when the high tension power lines were 150+ yards away. This may not be the case for you as it has been for me but if there is any takeaway here, be extremely cautious around power lines. The actual geography of the location may have also played a roll in it. Because of the hills on either side, almost like a canyon, some of the GPS signals had to pass through the radiation given off by the power lines. I only say it's been debated because many on my YouTube video claim it was the compass or the VPS which was on during the flight. I completely disagree with that as I have used process of elimination to determine it could only be the power lines.
I noticed after the firmware with my Phantom 3 Professional with VPS off that there is a little bit of sway while ascending and descending. I don't know for sure but I seem to recall that not occurring prior to the update and I did run the IMU, compass, and remote calibrations after the updates. Nothing too drastic at all but thought it would be worth mentioning.
Do you know if it is now faster after the update? Because as you suggested it does seem to be ascending and descending quite a bit faster. Along with horizontal movement, forward and back seem faster too. I'm loving it, I took it out and did some low altitude flying to show off how fast this baby can fly. Personally I believe the fast descending is a must. Even at the 400 foot limit, there are at times, planes flying below 400 feet off the shore of some of the beaches I fly at in Southern California. I like the option of being able to get out of dodge as fast as possible!
