RC Pro pairing to Mini 3 Pro timed out
764 4 2022-9-14
sakumar
Flight distance : 239134 ft
I have a DJI RC Pro that came with my Mavic 3 Cine.
I have been unable to pair it to a new DJI Mini 3 Pro that I ordered without any remote.
Firmware versions are as follows (and I downloaded twice using the DJI Assistant 2 just to be sure):
RC Pro: 03.01.0900
Mini 3 Pro: 1.00.0300
After I start the pairing procedure, the Mini 3 Pro's four green leds blink one at a time (left to right).
The RC Pro's Blue LED is on and the unit beeps continuously.
This goes on for a full minute and then I get a "Pairing Timed Out" message on the RC Pro.
I would appreciate any help in troubleshooting this. Thanks.
2022-9-14
sakumar
Good news -- the issue has been resolved.
Here's the process:
A) First make sure that both the RC Pro and the Mini 3 Pro have the latest firmware. Currently 9/15/2022 it is V03.01.0900 for the RC Pro and 1.00.0300 for the Mini 3 Pro. I used the DJI Assistant 2 (Consumer Drone Series) app.
B) There are three different ways to set the RC Pro in pairing mode. Only the last one (iii) worked for me.
    (i) Press and hold C1, C2 and the Red Record button till the RC Pro starts beeping, a blue light is flashing and it is counting down from 60 seconds.
    (ii) DJI Fly -> Connection Guide -> Camera View -> ... -> Control -> Re-pair to Aircraft (Link) [The last one is all the way down, in blue colored font]
    (iii) DJI Fly -> Connection Guide -> "DJI MINI 3 PRO" -> [After Searching for Aircraft it displays ] "? Unable to connect to aircraft ? " in blue. Click on that, start the pairing process on the Drone by pressing the power button for > 4 seconds till the motors make a momentary buzzing sound, and then clicking "Pair" on the DJI RC Pro screen.
In part B) (iii) make sure you select the correct drone model.
2022-9-15
DJI Stephen
Super Moderator
Hello there sakumar. I am sorry for the trouble this has caused before and it great to know that the issue has been rectified and for giving out these information as well on how you have solved the issue. Have a safe and a happy flying always.
2022-9-15
djiuser_RRcq0SjXwJ6V
Bermuda
sakumar Posted at 2022-9-15 09:43
Here's the process:
Dji Mini 3 Pro
I am having the same problem with timing out when I’m trying to pair my DJI mini three pro with the DJI RC.
I have updated the firmware on the drone and DJI RC and  I’m still having the issue with pairing. It keeps timing out.
Nobody is mentioning a solution for this issue on the forum yet?
This is brand new out of the box today purchase both items together??
Both the drone and DJIRC are fully charged. I have looked on YouTube &  forums and no one has mentioned how to resolve this issue.
3-22 07:35
mcozy52
Same issue here with Mavic 3 and DJI RC.  Firmware is updated on both. Batteries are fully charged. Could I be walked through the different techniques for the pairing of these two. Thank you in advance.
3-22 16:15
