gulfpre
Flight distance : 2404140 ft
TheBoy Posted at 9-15 06:50
Well, if its pretty common, DJI need to pull their finger out and fix the issue! I don't really see this when using other aircraft that use the other DJI remotes.
And how would I manually upload the flight logs to DJI from a DJI RC?
I think the problem is the usage of the smart controllers, RC/RC-Pro.
This issue wasn't nearly as prevalent when using a phone/tablet that remained on, vs the smart controllers that tend to get turned off, shortly after use. Interrupting the upload process.
I have run into the same issue, and take note, verify sync'ed flight logs on a different device, usually cell phone or tablet, and if logs show funky, I start up the RC/RC-Pro again and manually push up the logs.
Sometimes having to delete the "corrupt" sync'ed log on the other devices, and clearing the specific flight in AirData. |
