USB-C Mic
4803 14 2022-9-16
johansenfoto
Flight distance : 1180089 ft
Norway
Since OA3 supports recording through USB-C without any adapter, any tips which mic to get?
And I wonder if there is possible with stereo recording and not only mono.
Another solution is to get usb-c to mini-jack adapter.
2022-9-16
WiscoPaddler
I would imagine any mic would work well.  Rode Wireless or the DJI wireless mic.  I'll be using the Rode Wireless Go II myself.
I'm hoping/banking the old USB C converter for mic and power will work for this.  I'd like to power the camera and plug a mic in at the same time.  It worked great for the original Osmo Action and would be surprised if it doesn't work on the Action 3.
2022-9-16
johansenfoto
Norway
WiscoPaddler Posted at 9-16 06:03
I guess that too. But I should actually wrote that I struggle a bit to find any usb-c mic that doesn't have really long cable.
1 feet (30 cm) would be perfect.
2022-9-16
DJI Stephen
Hello there johansenfoto. Good day and thank you for reaching out. You may used the DJI Mic on the DJI Osmo Action 3 by connecting the receiver of DJI Mic to the DJI Osmo Action 3 USB-C port using a Type-C phone adapter then link the receiver and transmitter of DJI Mic. Thank you.
2022-9-16
johansenfoto
Norway
DJI Stephen Posted at 9-16 19:06
Thank you, but it costs a little too much for my need. But I did think about that solution
2022-9-17
fansfe82067d
There were a number of threads about this in relation to the Action 2 - might be worth a rummage in that forum.
Here's some possibles - I think it would be 90% likely that whatever works with the Action 2 will work with the Action 3 as their internals appear to be the same -
https://forum.dji.com/thread-254671-1-1.html
2022-9-17
johansenfoto
Norway
fansfe82067d Posted at 9-17 05:40
Thank you so much for the thread and the videos, I will check them out and I have already seen many of your videos from before because you give good tests of gears
2022-9-17
fansfe82067d
johansenfoto Posted at 9-17 06:19
I'm glad to have helped!  The Action 2 is meeting my needs very well so I do not plan to purchase the Action 3, but anything on my YouTube channel about the Action 2 will probably apply to the Action 3 also.
2022-9-17
DJI Stephen
johansenfoto Posted at 9-17 00:57
Hi there johansenfoto. Thank you for the reply and for these information. If you have any other inquiries or any concerns with DJI. Please feel free to post it here at DJI Forum. We are all here to help and assist you.
2022-9-18
switzerorider
Hi, I want to use the DJI Mic with the Osmo Action 3, but to avoid the weight I'd like to put the receiver in my pocket = i need a USB-C cable extension that is recognized by the Osmo Action 3 as a Mic.
All cables I tried are not working, any idea which one i can use? Thank you
2023-3-19
DJI Tony
switzerorider Posted at 3-19 14:03
Hi there. Thanks for reaching out, and we're sorry to read about the difficulties you encountered. DJI does not have a list of recommended cables, but you can use a standard type-C cable. Ensure you remove the Osmo Action 3 Horizontal-Vertical Protective Frame when connecting Osmo Action 3 to DJI Mic. We hope you can get some recommendations from your co-users here. Thank you, and have a nice day.
2023-3-19
Ravi Dagar
India
Hello I’m also looking for external mic option for osmo action 4. I heard most of the mics doesn’t work properly. I just bought it for motovlogging and I’m from India.
2024-7-26
MiniManiac
Flight distance : 1474354 ft
take a look at this cheap as chips microphone i got from Aliexpress, videos of sound included in thread
https://forum.dji.com/forum.php? ... p;page=1#pid3368763
2024-7-27
JerryN
I built up a Small Rig with a Small Rig Cage, a Cinematic bar with 1/4" holes,  knurled aluminum handles on each end.  Movo external microphone on one hot show on the bar,  Small Rig light on the other end. Osmo Action camera in the middle.  It worked  fine as pictured and awesome for family video. I'm shooting at 2.7k and the camera overheats so I figured I would go with an external battery.  I bought a usb power splitter.. it appears that the stinking camera switches off the microphone when using an external battery.  Why ?  The camera overheats so most of us want to use an external battery.  Is there a firmware fix for this ?
I have a message for DJI.. since the small camera body can't dissipate the heat properly, please update the firmware to not disable the external microphone while operating on external power!
2024-7-31
DJI Natalia
JerryN Posted at 7-31 06:17
Hi there, thank you for reaching out and share us your feedback. We truly understand your concern and we will consider this as a suggestion. Your valuable feedback will be promptly forwarded to the relevant team for a thorough evaluation. We would like to assure you that we are committed to providing the best user experience.
Thank you for your continued support.
2024-7-31
