Rockel83
aliveathome Posted at 10-13 07:59
Yes, I did the same and agree with you, it's hard to tell if its bad or good Would be interesting to see someone elses photos of the same pattern. Maybe my camera is fine after all?
Yes I know, no it's not my adress, its a company a bought some stuff from a long ago. I kept it there just to get the text in the picture. Thanks for the heads up anyway
Well, I thought it could have been a good neutral test to test like this. So everybody will be able to perform the same test.
But did not expected that it would look that far away.
Zooming in seems to be not that great option too, because it seems to get more grainy fast then. And not all the software will behave the same whe zooming in. I've used a few fotoplayers before to arrange some holliday foto's and they all looked different when zooming in. So therefore I thought that Photoshop would have been a reliable option here.
Maybe the use of a "universal" chart is usable. But maybe we will need some refference points to compare it with? Like if someone could perform the exact same test with the same chart with other camera's> Let's say the GoPro's or even the OA1?
Maybe it can be also usable to use a less detaild chart? What do you think of the 3 options I've put in one of my previous message? I believe the last one is exactly the same as that you're using here.
But again, your tests seem to be pretty sharp!
