Reporting a problem I encounter using head tracking and motion controller. As you can see in the video at 10 sec mark the head tracking and motion controller went out of sync and couldn't determine the location where it was facing. At 20 sec mark Had to press brake function and turned off head tracking to gain control and seemed to be fine after that. Had to upload to YouTube couldn't upload the video here.
Hi there. Thank you for reaching out and we're deeply sorry for the trouble that this has caused. Can you please try to connect your DJI Goggles 2 and the DJI Motion Controller on the DJI Assistant 2 and kindly please update/refresh the firmware to see if the issue persists? You may refer to the link below for you to download the said software on your computer. Please keep us posted. Thank you.
DJI Paladin Posted at 9-27 22:00
The firmware are all updated when the issue happened. This has happened twice already. I have turned off head tracking for now and have had no issues so far using motion controller.
Usually happens if I turn my body/head while in flight and don't realize it (usually while standing)... head traking uses your head position, including direction; the brake button re-centers. It's normal operation. Try sitting in a chair.. re-center with your head straight and focus on keeping your head straight IF you need to hit the brake button. (re-center) It takes some time and practice. If you hit the brake with your head turned right... that becomes the new "center". You'll get it.
Might also be better to post the video from the goggles 2 also... since it shows the center "o" thingy.
I found no mention of this anywhere in the manuals either.
Bob Brown Posted at 9-28 09:31
Usually happens if I turn my body/head while in flight and don't realize it (usually while standing)... head traking uses your head position, including direction; the brake button re-centers. It's normal operation. Try sitting in a chair.. re-center with your head straight and focus on keeping your head straight IF you need to hit the brake button. (re-center) It take some time and practice. If you hit the brake with your head turned right... that becomes the new "center". You'll get it.
Hi Bob yeah that’s what I’m doing. Only fly with goggles sitting down. It’s fine for about 5 mins with head tracking and then it seemed to have lost direction with motion controller. I do have a video and you will notice it at 10 sec mark. Had to press the brake to regain controller. https://youtu.be/k-AY4BUJ0UE
Jaybpena Posted at 9-28 09:41
Try Calibrating everything. I think I recall having a strange issue like this and I hunted for all the calibrations and after that the issue was gonzo.
Bob Brown Posted at 9-28 09:45
Will try that and test out head tracking again. Lol I have it turned off for now since the incident.
Jaybpena Posted at 9-28 07:39
Thank you for keeping us posted, Jay. Kindly please let us know if this issue still persists on your next try to use the Head-Tracking. You may try to refresh the firmware using the DJI Assistant 2 first before using it. Thank you for your kind and understanding.
I've had some similar issues in my testing, but I wasn't sure if it was me or the goggles. I would just need to tap the brake and it would recenter. Its a super immersive flying experience with head tracking, but hard to trust it for technical flying at this point.
Yes same problem 3 days ago..
Basically head tracking spun 180 degrees instantly and the drone just wanted to fly BACWARDS. To make it stop was full throttle.. luckily the drone did not go off the 70m waterfall.
Now I've learnt to hit the stop button... but that is a major bug there.
P.S. I've been building and flying UAS for almost 10 years and every stage of FPV... never had that happen.
DJI.. please fix. I'm happy to send the log file.
fans396494c9 Posted at 2022-12-31 00:41
The same thing happens to me. does a 180 out of nowhere. Either that happens every flight or the head stacking is doing nothing. I only used the Motion 2 controller over the FPV controller because I hurt my thumb recently. def has to be a bug.
