Problem to connect external microphone by 3.5mm
850 8 2022-9-23
clmmaurin
Hello there,
I use DJI Osmo Pocket 2 with creator pack. The microphone contained in the creator pack (with the external receptor) work's perfectly, but dosen't work if i connect a lapel microphone by 3.5mm.
I tryed with two differents lapel microphone, also without the external receptor (connecting directly to the OSMO). I take it that the problem come from the external receptor... Is anyone ever heard about this problem ? Any solution to propose ?
Thank you.
2022-9-23
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
would u plz post a picture of the mic u are using? pocket 2 do-it-all handle supports 3-segment microphone and some of 4 seg mic.
2022-9-23
clmmaurin
Thank you for your answer.
I use this microphone Rode.
Need more info ? I can check, as you want.
Thank you.
2022-9-23
fansfe82067d
Are you trying to use the wireless mic and the 3.5mm mic at the same time?  I don't think that is possible.  To use the 3.5mm mic I suggest turning off the wireless mic, turn off the Pocket 2, then turn the Pocket 2 back on, then connect the 3.5mm mic - and see if it still does not work.
2022-9-23
HGDC84
Finland
Does the lapel work when you connect the lapel to the Do-It-All Handle's 3,5mm connector? Or does the problem occur in that case too?
I'd also check out the connector on the lapel mic. I use Rode SmartLav+ with my DJI Pocket 2 wireless mic and that works just fine. But you might get different results on different lapels.
2022-9-24
clmmaurin
fansfe82067d Posted at 9-23 16:00
Not at the same time to record. But to use the lapel mic 3.5mm far from the OSMO I have to use the wireless mic as a receptor, and then, connect the lapel mic 3.5mm.
2022-9-27
clmmaurin
HGDC84 Posted at 9-24 13:56
The problem occur in that case too... It seem like the problem come from the receptor because it works also perfectly with the DJI OSMO Pocket 1.
2022-9-27
paul420
Algeria
wait what's the name of this mic ???
2022-9-27
clmmaurin
paul420 Posted at 9-27 07:19
Rode Lavalier Go, sell with the wireless transmitter rode TX-Belt.
https://www.missnumerique.com/rode-lavalier-go-p-46856.html?utm_source=google&utm_medium=css&utm_campaign=kelkoofr&ref=3560mcrapla&esl-k=google-ads|nx|c|m|kpla|p|t|dc|a|g17784370950&gclid=CjwKCAjwvsqZBhAlEiwAqAHElRcpWxOqGyL1ZDC_d2gwzkcNSAATUDSbOpCN3ZYZh28-zVs6qFgNzxoCJEcQAvD_BwE
2022-9-27
