DJI Paladin
Hi there. Thank you for reaching out. As per checking on the image that you sent to us, it shows that there is no issue with the propellers and you can use it as normal. We strongly recommend replacing propellers if it does damage like a crack or broken plastic. You may try to test flight your unit and hover it in place to check the stability. Please keep us posted. Thank you. |
