Aavalaakso
Finland
osmonauta Posted at 9-24 11:26
Previously, I used to shoot with 30 fps because my phone was not capable or shooting 60. Then I started shooting 60 on my new iPhone because every time I panned, or a car passed by, it appeared jarring. With 60 fps the panning and other fast motion was/is way smoother.
Of course I am not a videographer and not familiar with filming "science", I just shoot for myself basically. But now that I'm getting an action cam, I might start reading up on this "science"...
Yes 60 fps is way much smoother than 30 because it takes 60 motion stops per second. But it requires a lot of light. You need to take 60 frames during one second. So each frame cant have more time to gain light than 1/60 sec. In 30 fps it has double time to gain light. If you have light then 50 or 60 is totally fine but when its getting dark and if you shoot 60 fps and if 1 frame is not gaining enough light sensor becomes more sensitive meaning more Gain aka pushing ISO value more up leading more Noise in the picture leading EIS to start fail because the image is not clear anymore to compare i/p frames direction.
Try it yourself. In very low light, there is clear difference between 30 fps and 60 fps. Lower is brighter with same ISO value. |
