WernerD
Flight distance : 350837 ft
Austria
Not 100% sure as some drones behave differently but because the Avata does not have obstacle sensors in all directions, I assume it is the following:
If far away, it hovers, flies straight up to the RTH defined height, direct flight to the home point and vertical descent there. If there are tree branches in the way - big problem.
If close, it lands immediately at the spot by simply descending vertically. If your start point was the only safe landing point in the vicinity, problem.
In both cases, approx 1m above ground, the downward vision sensors check if the landing spot is suitable, else it stops the landing procedure unless the RTH kicked in due to low battery warning.
If you walk, the home point is not(!) updated. But there is a button to update the homepoint to the current location on request. Continuous update has been requested as enhancement but not been implemented with any. |
