djiuser_Fkc0IME6jL10
I've used my new avata a few times since buying it on the first day and I keep running into the same problem.
I'm using the motion controller in normal mode
Any wind /breeze renders the avata useless. The avata gets pushed around very easily.
During a flight over moving water, the avata stalled in midair and wouldnt move forward (odd). I turned the drone downstream and the avata flew out of control at high speed.
Another flight with minor wind, the avata would not turn into the breeze. AGAIN, these are conditions i have flown the mini2 with no problem
The avata view through the goggles also doesn't level out after looking up or down. The image is very tilted in the goggles. Please help
1) Do the sensors on the bottom of the avata help the avata stabilize at all?
2) Does the avata measure it's getting speed with the down facing cameras?
3) What would cause the avata brakes to not work?
4) What would cause the home point to shift during flight by itself?
5) What are the wind speeds the avata can handle in normal and sport modes?
When i contacted DJI the rep said i was past the 15 days to exchange.
I was told to record both my mini2 and the avata in wind.
please help. thank you
