DemolitionMan14
Flight distance : 1963583 ft
GoPro released the Hero 11 recently and they did something I thought was interesting. They included an almost square (8:7) image sensor fpr the purpose of horizon lock. That got me thinking about the benfit of a square sensor. The original Mavic Pro had a portrait mode which was acheived by rotating the gimbal 90deg. That feature has been absent on the Mavic 2 Pro and the Mavic 3. This is presumably due to the gimbal design not allowing 90deg rotation of the camera, as the camera and gimbals are bigger on the newer Mavics. Enter the square sensor, If DJI developed a square sesnor that would allow for a portrait mode without limitations of the gimbal. At the minimum, I would keep the long dimension of the Mavic 3 camera and increase the short dimension to match it. I would then have setting that you can apply guidelines in the most popular aspect ratios or set the camera to preview the most popular aspect ratios (4:3, 3:4, 3:2, 2:3, 16:9, 9:16 or 1:1) on your screen but save the full sensor read-out in RAW mode. This would allow for you initial framing of the shot but also allow you to go back and reframe if needed. On my Canon R5 the Sensor is 3:2 but I can set the aspect ratio to 16:9 or 1:1, but the RAW file saved to the memory card is the full sensor read-out not just the cropped image. Im interested to hears thoughts and discuss this.
