Gimbal starts tilting upwards when moving left to right on Landsc..
575 6 2022-9-26
fans19d6cad7
Flight distance : 110663 ft
Hi,
I have recently gotten Osmo Mobile 6 and was wondering if anyone is experiencing an issue where the gimbal starts to automatically tilt slightly upwards over time on landscape mode when moving the Osmo Mobile 6 left to right? I have to always press the trigger to recenter the gimbal. Is this normal? I have updated the firmware and I was using Iphone 13 pro max with a transparent case which weighs 1.3oz (approx 36.9 grams), the phone weighing 8.4oz (238.14 grams), and grand total of 9.7oz (275.04grams). Is there a fix to this solution or is this a defect?
2022-9-26
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to perform the gimbal calibration to see if the issue persists? In addition, could you please provide us with short video footage showing the issue for us to check it here on our end? Please keep us posted. Thank you.
2022-9-26
Curt1591
Thailand
Is your phone in a protective case? If so, remove the case; it can cause an imbalance.
2022-9-27
dlimbizkit
Curt1591 Posted at 9-27 14:56
The max weight on the Osmo Mobile 6 is 290gram. So, it should still work perfectly fine. I asked a DJI rep, and they said that's normal. So, I'm... wondering if that is true.
Phone Specification from DJI for Osmo Mobile 6
2022-9-27
Curt1591
Thailand
dlimbizkit Posted at 9-27 15:56
[view_image]
I had the original Osmo Mobile. I had the same problem the OP is having. I took off the cover and the problem went away.
My problem wasn't the weight; it was the imbalance the case caused.
With the new "curved" phone mount, who knows?
"I asked a DJI rep, and they said that's normal."
Interesting that a wandering gimbal is "normal" on a video stabilizing device.
Maybe "common" might be a better term.
2022-9-27
bheiser10
Flight distance : 658015 ft
@fans19d6cad7 did you find a solution to this?
2022-10-5
dlimbizkit
bheiser10 Posted at 10-5 06:58
I have tried the calibration method and it seems to work. But I'm going to do more test to see if the problem still persist.
2022-10-5
