Why your DJI Avata is crashing!!!!! (MAYBE)
6949 31 2022-9-28
Cauffy
Flight distance : 48451 ft
Interesting video, just sharing information I have seen.
2022-9-28
Woobisah
Flight distance : 1702457 ft
People need to practice more in manual mode, when I first started I would make these quick hard stick input moves that would lead to bad results or crashes.  It doesn't take much stick input to do what you need it to do.  Also this isn't a Freestyle drone.  While you can do most moves, this drone isn't what it was made for.
2022-9-28
DAFlys
Thanks for sharing.
2022-9-29
arkchan
Flight distance : 1655138 ft
i appreciate the analysis, but dont think thats the real reason why the Avata flip itself in M mode while doing a quick turn.
IMO, the firmware seems to be the problem where the algorithum try to adjust itself but having an wrong compensation instead.
Many experienced pilots are having the same issues so I dont think its the pilot him/herself causing this.
I have 100+ hours flying FPV, although I havent encountered this issue yet, I have grounded mine for safety.
Luckily still got my DJI FPV and it still goes well.
Hope DJI can find out the Avata fatal bug and get it fixed asap as it really concerns many pilot from flying it again.
2022-9-29
Montfrooij
Flight distance : 2845026 ft
Thanks for sharing!
2022-9-29
DowntownRDB
Flight distance : ****
Nice share.
2022-9-29
Bob Brown
Flight distance : 4209662 ft
makes sense. sticking with the MC and close range flights. might have a RC2 for sale on ebay. lol
2022-9-29
Nees
Flight distance : 80991 ft
Belgium
Woobisah Posted at 9-28 16:02
That is your opinion, if it shouldnt be flown like that... most people dont know that and can cause damage.
If its not meant to be, limit something or smooth something out if the input on stick is to large to handle by the drone. Or if the drone detect that fall, its goes automattically into a break/pause mode like you press the button, ofcourse that is not ideal, as you might be on the the limit and recover it yourself...
But im sure this can be smoothed out more
2022-9-30
Woobisah
Nees Posted at 9-30 05:20
It's called Manual mode, there is no intervention.  You either hit the break button yourself and/or learn how to get out of the situation.  I'm not blaming Honda that I can't turn my SUV a full 180 while driving down the highway, by just turning the steering wheel to the left.  From what I've seen in most of the videos and I haven't watched them all, the pilots are basically hard sticking the yaw to the left or right, this will dip to one way or another as the drone is not level but it actually pitched forward so you are not yawing at a level horizon so you need some roll/ throttle with it as well.  It is also losing lift due to the air going over the ducts of the quad, which is why you see the big drop.  This is just physics plain and simple.  So they either need to stay in Normal/Sport mode or learn how to fly manual more than just a few hours in a sim.  Plus if you are just learning to fly manual, the last place you want to be is near water.
2022-10-2
celltx
Flight distance : 7399311 ft
Israel
One more attempt to explain the crashes:
2022-10-2
Mat8861
Flight distance : 169400 ft
Woobisah Posted at 10-2 22:34
We talking about something wrong in the avata. There are videos where the user flies with motion controller, no acrobat and crazy things. It's hard to believe that ducted or not, a drone doing a manouvre like quick turn, then goes upside down, there are tons of cinewhoops and cinelog drones that can handle that, you may go side-down a bit, but not totally upsidedown which is = crash, not only....... a dangerous crash.
I believe in DJI, the mini 3 pro flies wonderful, nice pictures and videos, a step in the future for aerial photography, but please don't tell me there is nothing wrong with AVATA!!! I hope it gets fixed soon.ps
with motion controller only 2 modes available......
2022-10-3
Woobisah
Mat8861 Posted at 10-3 11:08
This guy is explaining it better than I can.
2022-10-3
HDPS
Flight distance : 44957 ft
Guess I have been luck so far, today was fairly windy and was doing dead sharp 180 degrees turns at 25 mph, not a wobble or anything unusual, sharp response always.  The only thing I am not comfortable is after the last Firmware the prompt "aircraft in low-power state" is always there when drone is on and parked, so far it has take off every time but for some pilots it became irresponsive. I have about 8 drones , 6 DJI and a beginner on FPV, will stick with Sport mode on Avata for a long time .
2022-10-3
OnePixel
Flight distance : 45049 ft
I agree with you
2022-10-4
MisterSpyezFPV
Flight distance : 1663 ft
2022-10-4
Mat8861
HDPS Posted at 10-3 21:21
I see the majority of crashes  seems to happen with MC (i might be wrong)...did you fly with MC or RC ?
Low power could also be an esc issue.
2022-10-4
MisterSpyezFPV
2022-10-4
HDPS
Mat8861 Posted at 10-4 01:29
Flying with the RC from my FPV...I think the Motion Control is too limited...and kind of prone to mishaps
2022-10-4
JAMh
Flight distance : 4754715 ft
a real expert analysis. there's no hidden secrets, it's very easy to see with this design
2022-10-4
MisterSpyezFPV
2022-10-5
deeve
Flight distance : 72864 ft
Just watched that video...Interesting. I would expect their engineers are working hard on a firmware update?
2022-10-5
MisterSpyezFPV
[url=]sportmodemccontroller[/url]
2022-10-5
TTV-VoidGG_
Flight distance : 138051 ft
Philippines
MisterSpyezFPV Posted at 10-5 06:34
https://youtu.be/E80Yl199pTs]sportmodemccontroller[/url]
Yeah, there's obviously something wrong with the Avata.
DJI should address this through firmware, or by doing a recall if they wont be able to fix this issue.
This video is not even going that fast and sharp.
Also, if you watch DJI's videos when they advertised this drone, they were going faster.
I don't know why they didn't fix this before sending this drone to production.
They obviously encountered this error during their test flights. Unless they only did a few ones before approving.
This issue scares me from flying Manual, and is actually limiting us from being able to maximise the potential of the drone (that we paid for).
I hope DJI fixes this.
2022-10-5
fans9db387d5
Unfortunately it also happens in normal mode, not even sport mode and with the motion controller! I seriously regret to have spent that much money for having a drone that I cannot rely on. And DJI does not do anything about it! They should recall them all and/or send fixed parts/drones for free before anyone gets hurt by a now well know issue!
2022-10-19
fans9d06815c
Flight distance : 9558930 ft
Singapore
1 more video here. Have they fixed the issue so far ?
2022-12-16
fans9d06815c
Singapore
1 more video here. Have they fixed the issue ?
I'm holding myself back from buying Avata.
2022-12-16
Woobisah
fans9d06815c Posted at 12-16 18:23
https://youtu.be/fcczR0p8XbA
Learn to fly and you wont have any problems.
2022-12-16
fans9d06815c
Singapore
Woobisah Posted at 12-16 18:47
learn to fly SLOW.....should be the term !
2022-12-17
HDPS
Avata Manual states....for freestyle and race flying, so, is not that it was not made for it...the intention was there but the design failed.
2022-12-17
ro_walker
Brazil
Thanks for sharing.
2022-12-17
Jake. A
Flight distance : 1205715 ft
2023-4-3
ro_walker
Brazil
Thanks for sharing.
2023-4-5
