KnNLmS
Flight distance : 119967 ft
Turkey
CutAussie Posted at 9-29 23:38
I found two issues with my Goggles 2
To see the bottom of the screen with status data I need to goggles a bit lower but then that partly blocks my nose.
Fix, I used a Dremel Tool with a Sanding Tool Bit to grind out a small amount of the hard rubber the bridges my nose.
DJI made very good job with Goggles 2 in general. Lightweight, high nit value, better antenna fitting etc.
But the ergonomic design for human face, there should be some work on it.
What you did, seems a solution but i believe DJI should work on that foam padding for better fit. |
