DJI Paladin
Hi there. Thank you for reaching out. When you connect the DJI Smart Controller to the DJI Air 2s aircraft, the SRC (O2) can be linked to the Air 2s (03) image transmission system. In addition, After SRC and Air 2S are linked well, the max transmission distance can reach the O3 standard, which's 12 km (FCC), 8 km (CE), 8 km (SRRC), and 8 km (MIC).
Note: SRC uses an O2 image transmission system, which is compatible with related aircraft with an O2 or O3 image transmission system. When SRC is linked to different aircraft, the max transmission distance will be different, and the max transmission distance depends on the aircraft used.
Lastly, We cannot upgrade the O2 transmission system to the O3 transmission system as it involves hardware upgrades and cannot be upgraded using firmware only. Hope this clarifies your query. Thank you for your valued support. |
