DJI Natalia
Update: Please check the following details:
1. Default setting for Zoom camera is always 2x. It can normally not be set to start with 1x.
For 1x magnification, it is recommended to switch to a wide-angle lens.
2. When switching from Wide camera to Zoom camera it always starts with x5 zoom. It can not be defaulted to the lowest zoom level or no zoom. This is the default setting of the APP and cannot be modified
3. When the M30T is connected to the D-RTK2, the D-RTK2 communicates directly with the aircraft, so it is necessary to ensure that the communication between the UAV and the D-RTK2 is good (no blocking and no interference)
4.If the height difference between the wide-angle and zoom photos taken at the same time is large, it is recommended to provide the original photos for further confirmation
5. GpsFusionAlt" altitude calculated for the fusion of GPS and barometer, the altitude value will be affected by the ambient air pressure, and the error is relatively large. "RTKAlt" is the RTK positioning altitude, which is an absolute altitude, and the error is relatively small.
6. The absolute altitude can also be understood as the normal altitude, when RTK is positioned, the absolute altitude is obtained, and the relative altitude is the altitude of the aircraft relative to the take-off position.
7. M30T is not professional photogrammetry equipment, the defined position is not the center of the lens or image, when it is GPS positioning, it is the center of the aircraft, and when it is RTK positioning, it is the phase center of the RTK antenna
8. In the case of RTK positioning, the height in the photo is ASL, and the unit is m.
9. "Surveying mode"=0 (not recommended for surveying and mapping operations), "Surveying mode"=1 (the accuracy of this photo is guaranteed, it is recommended for surveying and mapping operations)
