SwaroopK
Flight distance : 7526 ft
India
I have a SanDisk Extreme® microSDXCTM UHS-I Card, the one that the Mini 3 Pro recommends, but the aircraft is not recognizing it, even if the RC controller can see it and use it. Although I successfully formatted the SD card in the RC controller, the aircraft is not picking it up. I first experienced the same problem with this product when I bought it, but I subsequently discovered that the issue had been solved after a sequence of device powers-on. I turned on the aircraft first, then the RC controller, in the order described here. Now, though, it is not detecting even though I use the same sequence of power-on procedure.
Did anyone had this issue and was able to fix it? Can anyone please help or suggest?
Thank you in advance !!!.
