DJI Susan
Hi there, just to clarify, DJI Care Refresh is only eligible in the region where it was purchased. To ensure that you can enjoy the service normally, DJI Care Refresh and the corresponding product must be purchased from the same country or region.
The location where the accident happened does not matter. Therefore, if you purchased the drone and Care Refresh in Japan, the DJI Care Refresh can only be used in Japan, it does not enjoy the benefit in Hong Kong. And if you need to use the DJI Care Refresh, you will need to send the drone to the repair center in Japan, you may need to be responsible for the shipment cross country/region, and after the drone is replaced, the drone will be sent to a Japanese address (this shipment can be covered by DJI), and you may need to arrange the shipment to Hong Kong afterward.
For the flyaway case, it is similar to the regular DJI Care Refresh process mentioned above, the drone will be sent to a Japanese address, and you may need to arrange the shipment to Hong Kong afterward.
Hope this provides you with some information. |
