Blériot53
Flight distance : 6188465 ft
Dajuror Posted at 10-2 20:07
When you pull the images to stitch them together, on which card are they stored? The drone internal OR the micro SD. I’ve looked on both cards and see NO folders containing multiple images for stitching, I see no other image folder except one holding stills, video AND panoramic images ALREADY stitched (very poorly in my opinion).
If a DJI rep reads this:
If this is, indeed, the case and images requiring processing are no longer stored in separate folders would DJI consider changing this? Back to something say like the Mini2 has? it is particularly frustrating to spend the time and effort to get the shots when they are stitched together poorly or you can’t even find them to process them.
You don't specify which of your drones you're referring to, but from your comments I'm guessing it's your Mini3Pro with DJI controller. All images and video are stored on the SD card in the drone, also the stitched images from any Panos that you do. There's another SD slot in the controller, as you probably know. I keep a spare one in there, but I've not used it yet.
Don't forget, if you shoot in JPEG only the individual images will not be stored - just the finished panorama. You need to set the shooting mode to J-RAW to save the images as DNG(RAW) files.
These will be the ones to use for stitching in an external program, for a better result.
