change ink in the canon pixma printer so lets start with changing the ink cartridges on the printer now lets get the how to change the ink in canon pixma printer remove the papers in the printers and switch on or else the cartridges will never come out of the printer now turn on the printer and open the clip where the cartridges are there now the cartridges are there .the cartridges will move for some time and settled in the center of the printing area .note down the cartridge details and purchase exactly the same type you can even refill the cartridges and be careful while refilling it shake well before unwrapping the cartridge its a prevention for leakage problem every cartridge has a protective sticker remove it before installation reverse the way you remove them and insert the cartridge do it gently with less pressure and close the lid now change ink in the pixma printer . so remove the papers in the printer and switch on or else the cartridges will never come out of the printer open the printer and the cartridges will keep moving left to right inside it so it will settle down and slowly remove the ink cartridge pull the cartridge holder down and slowly remove teh ink cartridge add ink to the cartridge holder now close it so it wa really simple and easy but need to know how to manage if there is a problem here are some tips .
