Lorenzo97
Flight distance : 236729 ft
DJI Paladin Posted at 10-3 23:36
Hi there. Thank you for reaching out. If you want to check this using your Goggles, you may go to the menu, and then go to Settings > Safety > Find My Drone. It helps find the location of the drone on the ground by using the cached video in the goggles. IF the drone still has power, turn on the ESC beeping, and the beeping sound will lead you to locate the drone. Hope this helps. Thank you for your valued support.
Thank you for your answer, i got the drone, what i need is the video of the crash because show that during mid aur the drone broke a propeller |
