DJI Paladin
 Super Moderator
Hi there. Thank you for reaching out. If you have files on the internet storage of the DJI Avata and you want to transfer them, use a USB-C cable to connect the aircraft and the PC to export then. If the files are in the SD card, you can insert the SD card into the aircraft, use a USB-C to connect the aircraft to the PC, or put the SD card into the card ready, connect to the PC, and export the files. Hope this helps. Thank you for your valued support. |
