RS3 Pro Loses GH5 Camera Control Connection
2073 12 2022-10-2
a_ambrose
Setup:Firmware v01.00.01.00
Panasonic GH5 (Firmware V2.7) connected to the gimbal with the DJI camera control cable
DJI focus motor
Brief description of the problem:
While filming, the gimbal seems to lose camera control connection randomly.
Example of the problem:
While filming on the sidelines at a football game, I press the record start/stop button on the gimbal at the beginning and end of each play. The camera will start recording and stop recording as expected. This expected behavior lasts a few times, but occasionally the camera won't respond to pressing the record start/stop button. The only thing that remedies the problem is shutting off the camera and then turning it back on. After doing so, the gimbal displays that it is connected to the camera via the camera control cable. This seems to happen randomly because I can't determine anything specific that causes it. I'm using the USB-C camera control cable that came with the RS3 Pro and the cable is securely plugged into both the camera and the gimbal. It doesn't appear to be a physical disconnect between the camera and the gimbal when this problem happens.
Thank you.
2022-10-2
DJI Natalia
Hi, there.
Sorry for the late reply.
We will confirm the details with the relevant team and reply to you asap.
Please don't worry.
If there is anything else that we can help with, please just let us know.
Thank you.
2022-10-3
droneby321
Flight distance : 777067 ft
Following - I am having the exact same issue (using GH5 & RS3) and it's almost making the RS3 unusable for me as it has become so unreliable in keeping the connection.
2022-10-4
DJI Natalia
Sorry for the late reply. Here is the update:
1. When the video recording function of the camera cannot be triggered normally, check whether the camera icon is displayed on the upper left corner of the screen of the gimbal, or connect the APP to enter the system status-status list to check whether the shutter status is normal.
2. If it is normal, please confirm that the firmware version is the latest, restore the parameter settings of the gimbal, and then restart the camera and gimbal to test whether it still appears.
3. Replace the camera control line.
4. Connect the camera to the computer, use the control software of the camera brand, and test to see if it is the same. If it is the same, it means that the camera interface is abnormal.
Please keep us updated on your issue.
And if there is anything else that we can help with, please let us know as well.
Thank you for your support.
2022-10-5
a_ambrose
droneby321 Posted at 10-4 23:29
I definitely feel your pain. My first time using the RS3 Pro on a job and it did this. I thought it was a random fluke but it did it repeatedly throughout the evening. Very frustrating. I was using it on a job again last week and the same thing happened. No rhyme or reason as to what causes it -- it just happens. I thought maybe the USB-C cable was faulty but it doesn't matter. I also ensured the cable was securely plugged into the camera and gimbal.
2022-10-7
a_ambrose
DJI Natalia Posted at 10-5 17:56
After shooting with the RS3 Pro and GH5 the last two days, this happened repeatedly and seemingly randomly. When it happened the camera icon disappeared from the upper left corner of the gimbal screen. The remote icon was still present on the GH5 screen.
I have the latest firmware version for both the gimbal and the camera. Restarting the camera always fixes the problem but the length of time before it happens again is random.
I haven't been able to test the other points in your response but thought I would let you know these.
2022-10-10
DJI Natalia
a_ambrose Posted at 10-10 17:27
Thanks for the reply.
If you are convenient, you can test as suggested above.
In addition, if the replacement of the cable does not work, and the camera's computer software can be controlled normally, we recommend that you send it back for a further check. Here is the link: https://www.dji.com/support/repair
2022-10-10
djiuser_5skRz9TPMPBS
Portugal
Hi!
I have the same problem with Panasonic GH5S and Ronin RS3. It happened before with Ronin S, but not so frequently.
The camera randomly loses connection with the gimbal, start/stop recording button and focus wheel stops working. Rebooting the camera solves it temporarily.
Sometimes the camera will also randomly stops recording, when the connection drops.
I figure it's probably a camera issue, but I have the most recent firmware on both camera and gimbal. Any way to avoid this?
2022-10-14
a_ambrose
DJI Natalia Posted at 10-10 19:33
After further use of the gimbal and GH5, I noticed when the camera control was lost, the camera icon was still visible in the upper left corner of the gimbal screen.
2022-10-20
DJI Natalia
a_ambrose Posted at 10-20 16:40
Thanks for the update.
May I confirm whether the parameters of the gimbal have also been reset, and whether the software used by the camera and the computer can be controlled normally? If you can control it normally, please send it back for testing. Here is the link: https://www.dji.com/support/repair
2022-10-20
silverxiang
Hello, is there any update on this? I am having the same problem. Both my GH5 and GH6 can't connect to the DJI rs3. The screen gets stuck on "Enable Bluetooth on camera, View Camera Compatibility List on DJI Ronin app". Bluetooth is enabled, I tried both 'ON' and 'pairing' bluetooth modes. Connecting any of the mentioned cameras by USB C cable to the RSS input, doesn't change anything as well (even if I switch the usb mode to 'PC Tethering'). Please help me, I'm about to return the gimbal and go for ZHIYUN solution
2022-12-13
djiuser_3JYtJpMZot18
Having the same issue with my GH5 and DJI RS2 gimbal. Using the USB-C cable, I used to connect no issues and be able to use the record button functions on the gimbal etc, but for some reason I cannot get it to connect anymore. When I connect now it doesn't even come up with the USB mode on the camera anymore...
2022-12-20
Aphid83
Same here with Rs3 mini + Panasonic S5. From one day to the other usb connection doesn’t work. Is there a solution for the problem?
3-27 08:02
