BudWalker
Flight distance : 4499810 ft
It appears that the Motion Controller was being used. Unfortunately, the MC commands are not recorded in either the .txt or the .DAT log files.
But, it does appear the the Avata yawed 180° CCW. At the same time there was pitch up and roll CW. I'm guessing you did not spin the MC 180° or command roll or pitch?
Looks very much the left side of the Avata got caught on something.
More could be learned by looking at the .DAT log file. It's in the MCDatFlightRecords sub directory and has the name
FLYxxx-025-yyyyyyyyyyyyyy.DAT. The .DAT will have motor data that would indicate if one of the props got caught. In addition, the Z axis gyro data shows the rotation commanded by the Flight Controller as well as the actual rotation. If there is a difference that would indicate that the Avata was caught.
