Hello there.
I have a DJI Mini 2 since several months. I use the DJI Fly app on an Android phone.
Here are 3 ideas for improvement:
On-screen direction indicator Sometimes I want to go to a place that I can see through the camera of my drone (like a tree or a house). For example, I would like to fly in the direction of the antenna behind the forest: Full-size picture :
It would be very useful if it were possible to display an indicator at the top of the screen so that the centre of the screen could be immediately identified and the direction in which the drone was moving could be determined (when you move straight forward).
On-screen remote-control position and takeoff point indicator I would also like to suggest adding remote control and takeoff point indicators that move all around the screen to indicate the direction they are in. This may seem a bit duplicative of the compass, but it could be useful in the case of the map display.
Indicate the battery with the least charge cycle I thought it would be convenient if it was possible to know via a special manipulation on the battery charging hub which battery has the least charge cycle to use them equally. For example, double pressing the button on the charging hub would cause the indicator for the battery with the least charge cycle to flash. I don't know if it's possible, does the charger can read this information?
