SobesMS
Flight distance : 649196 ft
So I updated to 1.3.2 and took it out for a short, low-level flight. Phantom boots up, gimbal does it's little dance and then points forward, about 10 seconds goes by and the camera drops straight down and I get the "no signal" on screen. Flight and telemetry work perfectly. Would even get a view from the camera pointed straight down for a split second every once and a while.
I included the logs below just in case there was something that stood out in the details.
I'm pretty certain at this point that my first update to 1.3.2 bricked the camera/gimbal somehow even though I followed every instruction and got every appropriate LED and sound indicator. So the question now is do I wait for the next firmware update and see if things get resolved or do I start making the phone calls and get this thing sent in for service?
Standard log:
Result: Success.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3S_FW_V01.02.0008.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
========== 2015.08.04 22:23:06 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.08.04 22:24:57 =====================
Result: Abort.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.08.07 18:32:31 =====================
Result: Abort.
========== 2015.08.07 18:33:48 =====================
Result: Abort.
========== 2015.08.07 18:46:41 =====================
Result: Abort.
Packet: P3S_FW_V01.01.0009.bin
Upgrading ...
Result: Success.
========== 2015.08.10 15:25:41 =====================
Result: Abort.
Upgrading ...
Result: Success.
========== 2015.08.10 15:39:43 =====================
Result: Abort.
========== 2015.08.10 15:40:47 =====================
Result: Abort.
Upgrading ...
========== 2014.01.01 00:00:13 remo-con disconnect======
Upgrading ...
Upgrading ...
Upgrading ...
Upgrading ...
Result: Success.
========== 2015.08.10 19:33:27 =====================
Result: Abort.
Upgrading ...
Result: Success.
Hidden log:
[00011731][01 00] Firmware upgrade finished successfully.
[00011847]Done.
[00011953]Packet [C:\P3S_FW_V01.02.0007.bin] resumed, card sn [0xa0ce32b3].
[00012095]Version checking[2]...
[00012239][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00012384][03 06][00] v2.1.6.18 -> v2.2.6.8 need upgrade.
[00012498][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012669][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012840][11 00][00] v1.6.0.0 -> v1.6.0.0
[00012920][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013010][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013094][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013174][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013210][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013294][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00013414][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00013469][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00013504][01 00][05] v1.14.3061 -> v1.14.3061
[00013540][01 01][00] v1.7.2735 -> v1.14.3061 need upgrade
[00013575]Done.
[00013609]Firmware upgrading[2]...
[00013755][01 01] Firmware upgrade start...
[00044017][01 01] Firmware upgrade finished successfully.
[00044077][17 00] Firmware upgrade start...
[00137852][17 00] Firmware upgrade finished successfully.
[00137899][17 01] Firmware upgrade start...
[00200795][17 01] Firmware upgrade finished successfully.
[00200848][03 05] Firmware upgrade start...
[00271200][03 05] Firmware upgrade finished successfully.
[00271416][03 06] Firmware upgrade start...
[00567393][03 06] Firmware upgrade finished successfully.
[00570143][19 00] Firmware upgrade start...
[00733839][19 00] Firmware upgrade finished successfully.
[00733901][04 00] Firmware upgrade start...
[00790984][04 00] Firmware upgrade finished successfully.
[00791020]Done.
[00791072]Version checking[3]...
[00791129][03 05][05] v34.2.0.9 -> v34.2.0.9
[00791194][03 06][05] v2.2.6.8 -> v2.2.6.8
[00791238][04 00][05] v1.38.0.0 -> v1.38.0.0
[00791283][09 00][00] v1.7.0.3 -> v1.7.0.3
[00791373][11 00][00] v1.6.0.0 -> v1.6.0.0
[00791548][12 00][00] v1.8.0.0 -> v1.8.0.0
[00791623][12 01][00] v1.8.0.0 -> v1.8.0.0
[00791713][12 02][00] v1.8.0.0 -> v1.8.0.0
[00791823][12 03][00] v1.8.0.0 -> v1.8.0.0
[00791862][15 00][00] v1.1.2.0 -> v1.1.2.0
[00791939][17 00][05] v1.1.1.6 -> v1.1.1.6
[00792044][17 01][05] v1.0.2.5 -> v1.0.2.5
[00792104][19 00][05] v1.0.8.96 -> v1.0.8.96
[00792140][01 00][05] v1.14.3061 -> v1.14.3061
[00792173][01 01][05] v1.14.3061 -> v1.14.3061
[00792208]Packet upgrade finish successfully.
[00013123]========== remo-con disconnect. boot(15) ============
[00013231]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xa0ce32b3].
[00013310]Packet upgrade start...
[00013454]Packet checking...
[00013560]Done.
[00013665]Version checking[1]...
[00013827][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013991][03 06][00] v2.2.6.8 -> v2.2.6.8
[00014107][04 00][00] v1.38.0.0 -> v1.38.0.0
[00014221][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014367][11 00][00] v1.6.0.0 -> v1.6.0.0
[00014581][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014727][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014881][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015061][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015169][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015317][17 00][00] v1.1.1.6 -> v1.1.1.6
[00015456][17 01][00] v1.0.2.5 -> v1.0.2.5
[00015602][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015712][01 00][00] v1.14.3061 -> v1.14.3090 need upgrade
[00015819][01 01][00] v1.14.3061 -> v1.14.3090 need upgrade
[00015922]Done.
[00018028]Waiting for user confirm...
[00028169]Timeout, start upgrade automatically.
[00028337]Firmware upgrading[1]...
[00040972][01 00] Firmware upgrade start...
[00011775]Done.
[00011810]Packet [C:\P3S_FW_V01.02.0008.bin] resumed, card sn [0xa0ce32b3].
[00011851]Version checking[2]...
[00011908][03 05][00] v34.2.0.9 -> v34.2.0.9
[00011971][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012013][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012062][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012272][11 00][00] v1.6.0.0 -> v1.6.0.0
[00012362][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012441][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012517][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012611][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012650][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012717][17 00][00] v1.1.1.6 -> v1.1.1.6
[00012857][17 01][00] v1.0.2.5 -> v1.0.2.5
[00012921][19 00][00] v1.0.8.96 -> v1.0.8.96
[00012959][01 00][05] v1.14.3090 -> v1.14.3090
[00012997][01 01][00] v1.14.3061 -> v1.14.3090 need upgrade
[00013034]Done.
[00013072]Firmware upgrading[2]...
[00013213][01 01] Firmware upgrade start...
[00043467][01 01] Firmware upgrade finished successfully.
[00043507]Done.
[00043543]Version checking[3]...
[00043613][03 05][00] v34.2.0.9 -> v34.2.0.9
[00043689][03 06][00] v2.2.6.8 -> v2.2.6.8
[00043766][04 00][00] v1.38.0.0 -> v1.38.0.0
[00043823][09 00][00] v1.7.0.3 -> v1.7.0.3
[00043929][11 00][00] v1.6.0.0 -> v1.6.0.0
[00044023][12 00][00] v1.8.0.0 -> v1.8.0.0
[00044099][12 01][00] v1.8.0.0 -> v1.8.0.0
[00044199][12 02][00] v1.8.0.0 -> v1.8.0.0
[00044289][12 03][00] v1.8.0.0 -> v1.8.0.0
[00044327][15 00][00] v1.1.2.0 -> v1.1.2.0
[00044420][17 00][00] v1.1.1.6 -> v1.1.1.6
[00044518][17 01][00] v1.0.2.5 -> v1.0.2.5
[00044584][19 00][00] v1.0.8.96 -> v1.0.8.96
[00044620][01 00][05] v1.14.3090 -> v1.14.3090
[00044660][01 01][05] v1.14.3090 -> v1.14.3090
[00044695]Packet upgrade finish successfully.
[00012131]========== remo-con disconnect. boot(15) ============
[00012169]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012207]Packet upgrade start...
[00012260]Packet checking...
[00012301]Done.
[00012338]Version checking[1]...
[00012428][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012508][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00012560][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012624][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012748][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00012948][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013048][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013133][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013223][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013272][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013354][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013479][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013544][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013592][01 00][00] v1.14.3090 -> v1.20.3419 need upgrade
[00013633][01 01][00] v1.14.3090 -> v1.20.3419 need upgrade
[00013671]Done.
[00015711]Waiting for user confirm...
[00025761]Timeout, start upgrade automatically.
[00025846]Firmware upgrading[1]...
[00040790][01 00] Firmware upgrade start...
[00011735][01 00] Firmware upgrade finished successfully.
[00011787]Done.
[00011899]Packet [C:\P3S_FW_V01.03.0020.bin] resumed, card sn [0xa0ce32b3].
[00012053]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012205]Version checking[2]...
[00012350][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012514][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00012668][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012787][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012911][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013021][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013121][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013221][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013321][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013366][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013455][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013575][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013645][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013687][01 00][05] v1.20.3419 -> v1.20.3419
[00013739][01 01][00] v1.14.3090 -> v1.20.3419 need upgrade
[00013786]Done.
[00013825]Firmware upgrading[2]...
[00013989][01 01] Firmware upgrade start...
[00044284][01 01] Firmware upgrade finished successfully.
[00044352][17 00] Firmware upgrade start...
[00135922][17 00] Firmware upgrade finished successfully.
[00135980][17 01] Firmware upgrade start...
[00197735][17 01] Firmware upgrade finished successfully.
[00197795][11 00] Firmware upgrade start...
[00248660][11 00] Firmware upgrade finished successfully.
[00248899][03 06] Firmware upgrade start...
[00574889][03 06] Firmware upgrade finished successfully.
[00574964][04 00] Firmware upgrade start...
[00633039][04 00] Firmware upgrade finished successfully.
[00633082]Done.
[00633124]Version checking[3]...
[00633206][03 05][00] v34.2.0.9 -> v34.2.0.9
[00633279][03 06][05] v2.2.6.19 -> v2.2.6.19
[00633324][04 00][05] v1.40.0.0 -> v1.40.0.0
[00633383][09 00][00] v1.7.0.3 -> v1.7.0.3
[00633501][11 00][05] v1.7.0.0 -> v1.7.0.0
[00633588][12 00][00] v1.8.0.0 -> v1.8.0.0
[00633679][12 01][00] v1.8.0.0 -> v1.8.0.0
[00633814][12 02][00] v1.8.0.0 -> v1.8.0.0
[00633888][12 03][00] v1.8.0.0 -> v1.8.0.0
[00633938][15 00][00] v1.1.2.0 -> v1.1.2.0
[00634029][17 00][05] v1.1.1.7 -> v1.1.1.7
[00634149][17 01][05] v1.0.2.7 -> v1.0.2.7
[00634207][19 00][00] v1.0.8.96 -> v1.0.8.96
[00634250][01 00][05] v1.20.3419 -> v1.20.3419
[00634291][01 01][05] v1.20.3419 -> v1.20.3419
[00634336]Packet upgrade finish successfully.
[00012141]========== remo-con disconnect. boot(15) ============
[00012182]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012225]Packet upgrade start...
[00012276]Packet checking...
[00012320]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012365]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012407]Done.
[00012452]Version checking[1]...
[00012526][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012602][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012649][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012708][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012849][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00012938][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013018][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013103][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013203][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013244][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013342][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013552][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013627][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013669][01 00][00] v1.20.3419 -> v1.20.3419
[00013711][01 01][00] v1.20.3419 -> v1.20.3419
[00013774]Done.
[00015818]Waiting for user confirm...
[00025865]Timeout, start upgrade automatically.
[00025956]Firmware upgrading[1]...
[00026015][11 00] Firmware upgrade start...
[00076182][11 00] Firmware upgrade finished successfully.
[00076225]Done.
[00076268]Version checking[2]...
[00076355][03 05][00] v34.2.0.9 -> v34.2.0.9
[00076431][03 06][00] v2.2.6.19 -> v2.2.6.19
[00076478][04 00][00] v1.40.0.0 -> v1.40.0.0
[00076555][09 00][00] v1.7.0.3 -> v1.7.0.3
[00076672][11 00][05] v1.7.0.0 -> v1.7.0.0
[00076762][12 00][00] v1.8.0.0 -> v1.8.0.0
[00076861][12 01][00] v1.8.0.0 -> v1.8.0.0
[00076961][12 02][00] v1.8.0.0 -> v1.8.0.0
[00077061][12 03][00] v1.8.0.0 -> v1.8.0.0
[00077105][15 00][00] v1.1.2.0 -> v1.1.2.0
[00077216][17 00][00] v1.1.1.7 -> v1.1.1.7
[00077357][17 01][00] v1.0.2.7 -> v1.0.2.7
[00077411][19 00][00] v1.0.8.96 -> v1.0.8.96
[00077457][01 00][00] v1.20.3419 -> v1.20.3419
[00077503][01 01][00] v1.20.3419 -> v1.20.3419
[00077548]Packet upgrade finish successfully.
[00012166]========== 2015.08.04 22:23:07. boot(15) ============
[00012210]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012254]Packet upgrade start...
[00012304]Packet checking...
[00012347]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012395]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012437]Done.
[00012484]Version checking[1]...
[00012570][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012652][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012705][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012776][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012891][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012985][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013085][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013185][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013285][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013439][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013525][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013668][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013738][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013786][01 00][00] v1.20.3419 -> v1.20.3419
[00013832][01 01][00] v1.20.3419 -> v1.20.3419
[00013880]Packet upgrade cancelled at version checking.
[00012150]========== 2015.08.04 22:24:57. boot(5) ============
[00012198]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012241]Packet upgrade start...
[00012293]Packet checking...
[00012335]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012385]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012428]Done.
[00012471]Version checking[1]...
[00012564][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012647][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012701][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012785][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012905][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012990][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013086][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013186][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013286][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013332][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013410][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013530][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013586][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013631][01 00][00] v1.20.3419 -> v1.20.3419
[00013675][01 01][00] v1.20.3419 -> v1.20.3419
[00013732]Packet upgrade cancelled at version checking.
[00000838][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00011966]========== remo-con disconnect. boot(5) ============
[00012003]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012040]Packet upgrade start...
[00012090]Packet checking...
[00012208]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012247]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012284]Done.
[00012325]Version checking[1]...
[00012397][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012472][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012523][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012573][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012698][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012813][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012913][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013013][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013112][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013153][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013242][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013362][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013413][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013452][01 00][00] v1.20.3419 -> v1.20.3419
[00013489][01 01][00] v1.20.3419 -> v1.20.3419
[00013531]Packet upgrade cancelled at version checking.
[00011973]========== remo-con disconnect. boot(5) ============
[00012013]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012051]Packet upgrade start...
[00012100]Packet checking...
[00012143]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012183]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012221]Done.
[00012260]Version checking[1]...
[00012347][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012427][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012470][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012522][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012646][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012746][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012846][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012932][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013022][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013063][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013152][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013271][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013322][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013367][01 00][00] v1.20.3419 -> v1.20.3419
[00013405][01 01][00] v1.20.3419 -> v1.20.3419
[00013444]Packet upgrade cancelled at version checking.
[00013985]========== remo-con disconnect. boot(5) ============
[00014022]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00014062]Packet upgrade start...
[00014105]Packet checking...
[00014145]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014183]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00014222]Done.
[00014260]Version checking[1]...
[00014346][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014425][03 06][00] v2.2.6.19 -> v2.2.6.19
[00014471][04 00][00] v1.40.0.0 -> v1.40.0.0
[00014521][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014646][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014741][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014841][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014941][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015042][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015083][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015171][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015291][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015342][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015381][01 00][00] v1.20.3419 -> v1.20.3419
[00015420][01 01][00] v1.20.3419 -> v1.20.3419
[00015458]Packet upgrade cancelled at version checking.
[00011985]========== remo-con disconnect. boot(5) ============
[00012024]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012061]Packet upgrade start...
[00012113]Packet checking...
[00012155]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012193]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012230]Done.
[00012272]Version checking[1]...
[00012351][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012431][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012476][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012546][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012670][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012762][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012860][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012960][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013061][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013102][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013195][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013315][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013465][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013504][01 00][00] v1.20.3419 -> v1.20.3419
[00013547][01 01][00] v1.20.3419 -> v1.20.3419
[00013589]Packet upgrade cancelled at version checking.
[00011996]========== remo-con disconnect. boot(5) ============
[00012037]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012084]Packet upgrade start...
[00012131]Packet checking...
[00012173]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012211]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012253]Done.
[00012294]Version checking[1]...
[00012385][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012465][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012516][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012580][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012704][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012820][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012919][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013019][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013120][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013163][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013249][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013370][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013419][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013460][01 00][00] v1.20.3419 -> v1.20.3419
[00013501][01 01][00] v1.20.3419 -> v1.20.3419
[00013544]Packet upgrade cancelled at version checking.
[00011998]========== remo-con disconnect. boot(5) ============
[00012040]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012086]Packet upgrade start...
[00012133]Packet checking...
[00012174]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012214]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012254]Done.
[00012295]Version checking[1]...
[00012375][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012430][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012477][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012545][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012875][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013060][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013240][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013340][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013384][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013461][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013600][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013666][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013708][01 00][00] v1.20.3419 -> v1.20.3419
[00013766][01 01][00] v1.20.3419 -> v1.20.3419
[00013808]Packet upgrade cancelled at version checking.
[00012011]========== remo-con disconnect. boot(5) ============
[00012054]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012101]Packet upgrade start...
[00012150]Packet checking...
[00012196]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012238]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012279]Done.
[00012322]Version checking[1]...
[00012411][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012471][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012538][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012607][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012712][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012827][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012927][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013026][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013126][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013172][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013241][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013361][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013425][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013466][01 00][00] v1.20.3419 -> v1.20.3419
[00013507][01 01][00] v1.20.3419 -> v1.20.3419
[00013549]Packet upgrade cancelled at version checking.
[00012040]========== 2015.08.07 18:32:32. boot(5) ============
[00012090]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012132]Packet upgrade start...
[00012178]Packet checking...
[00012223]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012266]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012308]Done.
[00012351]Version checking[1]...
[00012423][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012505][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012655][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012714][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012844][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012940][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013021][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013119][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013220][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013267][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013377][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013513][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013575][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013620][01 00][00] v1.20.3419 -> v1.20.3419
[00013665][01 01][00] v1.20.3419 -> v1.20.3419
[00013710]Packet upgrade cancelled at version checking.
[00012062]========== 2015.08.07 18:33:48. boot(15) ============
[00012108]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012150]Packet upgrade start...
[00012197]Packet checking...
[00012245]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012289]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012332]Done.
[00012375]Version checking[1]...
[00012457][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012556][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012605][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012672][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012794][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012893][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013004][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013250][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013343][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013483][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013553][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013596][01 00][00] v1.20.3419 -> v1.20.3419
[00013640][01 01][00] v1.20.3419 -> v1.20.3419
[00013684]Packet upgrade cancelled at version checking.
[00496168]========== 2015.08.07 18:46:41. boot(5) ============
[00496221]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00496272]Packet upgrade start...
[00496329]Packet checking...
[00496471]Packet vlink 01.03.0020 <-> 01.01.0009.
[00496526]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00496574]Done.
[00496630]Version checking[1]...
[00496725][03 05][00] v34.2.0.9 -> v34.2.0.9
[00496828][03 06][00] v2.2.6.19 -> v2.2.6.19
[00496887][04 00][00] v1.40.0.0 -> v1.40.0.0
[00496963][09 00][00] v1.7.0.3 -> v1.7.0.3
[00497091][11 00][00] v1.7.0.0 -> v1.7.0.0
[00497188][12 00][00] v1.8.0.0 -> v1.8.0.0
[00497308][12 01][00] v1.8.0.0 -> v1.8.0.0
[00497409][12 02][00] v1.8.0.0 -> v1.8.0.0
[00497518][12 03][00] v1.8.0.0 -> v1.8.0.0
[00497571][15 00][00] v1.1.2.0 -> v1.1.2.0
[00497681][17 00][00] v1.1.1.7 -> v1.1.1.7
[00497815][17 01][00] v1.0.2.7 -> v1.0.2.7
[00497910][19 00][00] v1.0.8.96 -> v1.0.8.96
[00497971][01 00][00] v1.20.3419 -> v1.20.3419
[00498025][01 01][00] v1.20.3419 -> v1.20.3419
[00498076]Packet upgrade cancelled at version checking.
[00012970]========== remo-con disconnect. boot(15) ============
[00013027]Packet [C:\P3S_FW_V01.01.0009.bin] detected, card sn [0xa0ce32b3].
[00013072]Packet upgrade start...
[00013129]Packet checking...
[00013182]Packet vlink 01.01.0000 <-> 01.01.0000.
[00013232]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 1).
[00013276]Done.
[00013331]Version checking[1]...
[00013411][03 05][00] v34.2.0.9 -> v34.2.0.8
[00013510][03 06][00] v2.2.6.19 -> v2.1.6.18
[00013567][04 00][00] v1.40.0.0 -> v1.36.0.0 need upgrade.
[00013630][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013752][11 00][00] v1.7.0.0 -> v1.6.0.0
[00013834][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013945][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014046][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014134][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014184][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014275][17 00][00] v1.1.1.7 -> v1.1.1.2 need upgrade.
[00014415][17 01][00] v1.0.2.7 -> v1.0.2.4 need upgrade.
[00014497][19 00][00] v1.0.8.96 -> v1.0.8.59
[00014544][01 00][00] v1.20.3419 -> v1.7.2735 need upgrade
[00014592][01 01][00] v1.20.3419 -> v1.7.2735 need upgrade
[00014751]Done.
[00016800]Waiting for user confirm...
[00026851]Timeout, start upgrade automatically.
[00026950]Firmware upgrading[1]...
[00027111][01 01] Firmware upgrade start...
[00057392][01 01] Firmware upgrade finished successfully.
[00057470][17 00] Firmware upgrade start...
[00204266][17 00] Firmware upgrade finished successfully.
[00204332][17 01] Firmware upgrade start...
[00283950][17 01] Firmware upgrade finished successfully.
[00284030][04 00] Firmware upgrade start...
[00338656][04 00] Firmware upgrade finished successfully.
[00338704]Done.
[00338761]Version checking[2]...
[00338850][03 05][00] v34.2.0.9 -> v34.2.0.8
[00338931][03 06][00] v2.2.6.19 -> v2.1.6.18
[00338985][04 00][05] v1.36.0.0 -> v1.36.0.0
[00339051][09 00][00] v1.7.0.3 -> v1.7.0.3
[00339171][11 00][00] v1.7.0.0 -> v1.6.0.0
[00339285][12 00][00] v1.8.0.0 -> v1.8.0.0
[00339385][12 01][00] v1.8.0.0 -> v1.8.0.0
[00339510][12 02][00] v1.8.0.0 -> v1.8.0.0
[00339595][12 03][00] v1.8.0.0 -> v1.8.0.0
[00339651][15 00][00] v1.1.2.0 -> v1.1.2.0
[00339740][17 00][05] v1.1.1.2 -> v1.1.1.2
[00339875][17 01][05] v1.0.2.4 -> v1.0.2.4
[00339951][19 00][00] v1.0.8.96 -> v1.0.8.59
[00340000][01 00][00] v1.20.3419 -> v1.7.2735 need upgrade
[00340051][01 01][05] v1.7.2735 -> v1.7.2735
[00340105]Done.
[00340155]Firmware upgrading[2]...
[00353564][01 00] Firmware upgrade start...
[00011932][01 00] Firmware upgrade finished successfully.
[00011978]Done.
[00012022]Packet [C:\P3S_FW_V01.02.0008.bin] resumed, card sn [0xa0ce32b3].
[00012071]Version checking[2]...
[00012157][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012233][03 06][00] v2.2.6.19 -> v2.2.6.8
[00012285][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00012368][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012493][11 00][00] v1.7.0.0 -> v1.6.0.0
[00012582][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012672][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012747][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012827][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012952][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013042][17 00][00] v1.1.1.2 -> v1.1.1.6 need upgrade.
[00013162][17 01][00] v1.0.2.4 -> v1.0.2.5 need upgrade.
[00013227][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013271][01 00][05] v1.14.3090 -> v1.14.3090
[00013320][01 01][00] v1.7.2735 -> v1.14.3090 need upgrade
[00013365]Done.
[00013413]Firmware upgrading[2]...
[00013562][01 01] Firmware upgrade start...
[00043829][01 01] Firmware upgrade finished successfully.
[00043905][17 00] Firmware upgrade start...
[00134804][17 00] Firmware upgrade finished successfully.
[00134866][17 01] Firmware upgrade start...
[00197788][17 01] Firmware upgrade finished successfully.
[00197863][04 00] Firmware upgrade start...
[00011736][01 00] Firmware upgrade finished successfully.
[00011785]Done.
[00011832]Packet [C:\P3S_FW_V01.02.0008.bin] resumed, card sn [0xa0ce32b3].
[00011883]Version checking[2]...
[00011967][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012047][03 06][00] v2.2.6.19 -> v2.2.6.8
[00012102][04 00][00] v1.38.0.0 -> v1.38.0.0
[00012178][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012288][11 00][00] v1.7.0.0 -> v1.6.0.0
[00012382][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012482][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012582][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012662][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012710][15 00][00] v1.1.2.0 -> v1.1.2.0
[00012812][17 00][00] v1.1.1.6 -> v1.1.1.6
[00012933][17 01][00] v1.0.2.5 -> v1.0.2.5
[00012997][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013043][01 00][05] v1.14.3090 -> v1.14.3090
[00013091][01 01][00] v1.14.3090 -> v1.14.3090
[00013136]Packet upgrade finish successfully.
[00012303]========== 2015.08.10 15:25:42. boot(15) ============
[00012352]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xa0ce32b3].
[00012412]Packet upgrade start...
[00012475]Packet checking...
[00012530]Done.
[00012586]Version checking[1]...
[00012682][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012759][03 06][00] v2.2.6.19 -> v2.2.6.8
[00012936][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013011][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013141][11 00][00] v1.7.0.0 -> v1.6.0.0
[00013254][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013377][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013491][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013591][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013647][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013748][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013886][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013961][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014019][01 00][00] v1.14.3090 -> v1.14.3090
[00014076][01 01][00] v1.14.3090 -> v1.14.3090
[00014127]Packet upgrade cancelled at version checking.
[00012291]========== remo-con disconnect. boot(15) ============
[00012344]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012393]Packet upgrade start...
[00012445]Packet checking...
[00012493]Done.
[00012540]Version checking[1]...
[00012621][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012705][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012772][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012840][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012964][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013049][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013160][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013260][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013349][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013400][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013490][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013631][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013700][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013749][01 00][00] v1.14.3090 -> v1.20.3419 need upgrade
[00013796][01 01][00] v1.14.3090 -> v1.20.3419 need upgrade
[00013844]Done.
[00015893]Waiting for user confirm...
[00025942]Timeout, start upgrade automatically.
[00026040]Firmware upgrading[1]...
[00037991][01 00] Firmware upgrade start...
[00011942][01 00] Firmware upgrade finished successfully.
[00011992]Done.
[00012040]Packet [C:\P3S_FW_V01.03.0020.bin] resumed, card sn [0xa0ce32b3].
[00012186]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012237]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012288]Version checking[2]...
[00012398][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012498][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012558][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00012634][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012758][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012868][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012968][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013073][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013169][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013224][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013323][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013489][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013555][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013605][01 00][05] v1.20.3419 -> v1.20.3419
[00013655][01 01][00] v1.14.3090 -> v1.20.3419 need upgrade
[00013706]Done.
[00013757]Firmware upgrading[2]...
[00013906][01 01] Firmware upgrade start...
[00044191][01 01] Firmware upgrade finished successfully.
[00044266][17 00] Firmware upgrade start...
[00136971][17 00] Firmware upgrade finished successfully.
[00137040][17 01] Firmware upgrade start...
[00197774][17 01] Firmware upgrade finished successfully.
[00197853][04 00] Firmware upgrade start...
[00011840][01 00] Firmware upgrade finished successfully.
[00011892]Done.
[00011943]Packet [C:\P3S_FW_V01.03.0020.bin] resumed, card sn [0xa0ce32b3].
[00012000]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012054]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012106]Version checking[2]...
[00012191][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012291][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012348][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012426][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012551][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012666][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012765][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012867][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012987][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013049][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013235][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013381][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013466][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013519][01 00][05] v1.20.3419 -> v1.20.3419
[00013571][01 01][00] v1.20.3419 -> v1.20.3419
[00013623]Packet upgrade finish successfully.
[00012659]========== 2015.08.10 15:39:43. boot(5) ============
[00012708]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012758]Packet upgrade start...
[00012812]Packet checking...
[00012866]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012914]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012966]Done.
[00013015]Version checking[1]...
[00013125][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013225][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013286][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013362][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013487][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013596][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013697][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013797][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013923][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013974][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014068][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014209][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014298][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014348][01 00][00] v1.20.3419 -> v1.20.3419
[00014397][01 01][00] v1.20.3419 -> v1.20.3419
[00014446]Packet upgrade cancelled at version checking.
[00012126]========== 2015.08.10 15:40:47. boot(5) ============
[00012176]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012228]Packet upgrade start...
[00012283]Packet checking...
[00012334]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012386]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012436]Done.
[00012487]Version checking[1]...
[00012597][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012695][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012763][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012835][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012954][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013120][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013235][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013332][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013445][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013500][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013601][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013740][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013815][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013866][01 00][00] v1.20.3419 -> v1.20.3419
[00013916][01 01][00] v1.20.3419 -> v1.20.3419
[00013968]Packet upgrade cancelled at version checking.
[00012249]========== remo-con disconnect. boot(5) ============
[00012303]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xa0ce32b3].
[00012354]Packet upgrade start...
[00012412]Packet checking...
[00012467]Packet vlink 01.01.0000 <-> 01.01.0000.
[00012521]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 1).
[00012573]Done.
[00012632]Version checking[1]...
[00012713][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012793][03 06][00] v2.2.6.19 -> v2.2.6.8
[00012862][04 00][00] v1.40.0.0 -> v1.38.0.0 need upgrade.
[00012927][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013054][11 00][00] v1.7.0.0 -> v1.6.0.0
[00013147][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013250][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013368][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013493][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013550][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013643][17 00][00] v1.1.1.7 -> v1.1.1.6 need upgrade.
[00013769][17 01][00] v1.0.2.7 -> v1.0.2.5 need upgrade.
[00013847][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013903][01 00][00] v1.20.3419 -> v1.14.3090 need upgrade
[00013955][01 01][00] v1.20.3419 -> v1.14.3090 need upgrade
[00014010]Done.
[00016061]Waiting for user confirm...
[00026115]Timeout, start upgrade automatically.
[00026221]Firmware upgrading[1]...
[00026382][01 01] Firmware upgrade start...
[00056663][01 01] Firmware upgrade finished successfully.
[00056743][17 00] Firmware upgrade start...
[00014315]========== remo-con disconnect. boot(15) ============
[00014450]Packet [C:\P3S_FW_V01.01.0009.bin] detected, card sn [0xa0ce32b3].
[00014502]Packet upgrade start...
[00014558]Packet checking...
[00014611]Done.
[00014662]Version checking[1]...
[00014745][03 05][00] v34.2.0.9 -> v34.2.0.8
[00014825][03 06][00] v2.2.6.19 -> v2.1.6.18
[00014883][04 00][00] v1.40.0.0 -> v1.36.0.0
[00014970][09 00][00] v1.7.0.3 -> v1.7.0.3
[00015105][11 00][00] v1.7.0.0 -> v1.6.0.0
[00015215][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015314][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015414][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015514][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015568][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015655][17 00][00] v0.0.0.0 -> v1.1.1.2 need upgrade.
[00015755][17 01][00] v0.0.0.0 -> v1.0.2.4 need upgrade.
[00015831][19 00][00] v1.0.8.96 -> v1.0.8.59
[00015881][01 00][00] v1.14.3090 -> v1.7.2735
[00015935][01 01][00] v1.14.3090 -> v1.7.2735
[00015985]Done.
[00000837][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00012118]========== remo-con disconnect. boot(5) ============
[00012178]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xa0ce32b3].
[00012339]Done.
[00012390]Version checking[1]...
[00012483][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012584][03 06][00] v2.2.6.19 -> v2.2.6.8
[00012643][04 00][00] v1.40.0.0 -> v1.38.0.0
[00012709][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012849][11 00][00] v1.7.0.0 -> v1.6.0.0
[00012950][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013053][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013153][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013253][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013307][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013419][17 00][00] v0.0.0.0 -> v1.1.1.6 need upgrade.
[00013518][17 01][00] v0.0.0.0 -> v1.0.2.5 need upgrade.
[00013669][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013727][01 00][00] v1.14.3090 -> v1.14.3090
[00013777][01 01][00] v1.14.3090 -> v1.14.3090
[00013835]Done.
[00015887]Waiting for user confirm...
[00025941]Timeout, start upgrade automatically.
[00026048]Firmware upgrading[1]...
[00026124][17 00] Firmware upgrade start...
[00012235]========== remo-con disconnect. boot(5) ============
[00012289]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xa0ce32b3].
[00012343]Packet upgrade start...
[00012400]Packet checking...
[00012456]Done.
[00012509]Version checking[1]...
[00012622][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012721][03 06][00] v2.2.6.19 -> v2.2.6.8
[00012793][04 00][00] v1.40.0.0 -> v1.38.0.0
[00012862][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013002][11 00][00] v1.7.0.0 -> v1.6.0.0
[00013116][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013236][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013336][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013461][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013517][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013631][17 00][00] v0.0.0.0 -> v1.1.1.6 need upgrade.
[00013731][17 01][00] v0.0.0.0 -> v1.0.2.5 need upgrade.
[00013802][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013856][01 00][00] v1.14.3090 -> v1.14.3090
[00013909][01 01][00] v1.14.3090 -> v1.14.3090
[00013964]Done.
[00016016]Waiting for user confirm...
[00026069]Timeout, start upgrade automatically.
[00026172]Firmware upgrading[1]...
[00026247][17 00] Firmware upgrade start...
[00012157]========== remo-con disconnect. boot(5) ============
[00012211]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xa0ce32b3].
[00012265]Packet upgrade start...
[00012320]Packet checking...
[00012379]Done.
[00012433]Version checking[1]...
[00012518][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012618][03 06][00] v2.2.6.19 -> v2.2.6.8
[00012681][04 00][00] v1.40.0.0 -> v1.38.0.0
[00012758][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012901][11 00][00] v1.7.0.0 -> v1.6.0.0
[00013006][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013212][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013312][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013432][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013485][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013592][17 00][00] v0.0.0.0 -> v1.1.1.6 need upgrade.
[00013692][17 01][00] v0.0.0.0 -> v1.0.2.5 need upgrade.
[00013779][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013837][01 00][00] v1.14.3090 -> v1.14.3090
[00013894][01 01][00] v1.14.3090 -> v1.14.3090
[00013948]Done.
[00016000]Waiting for user confirm...
[00026053]Timeout, start upgrade automatically.
[00026161]Firmware upgrading[1]...
[00026235][17 00] Firmware upgrade start...
[00012161]========== remo-con disconnect. boot(5) ============
[00012215]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xa0ce32b3].
[00012269]Packet upgrade start...
[00012328]Packet checking...
[00012385]Done.
[00012441]Version checking[1]...
[00012529][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012627][03 06][00] v2.2.6.19 -> v2.2.6.8
[00012688][04 00][00] v1.40.0.0 -> v1.38.0.0
[00012765][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012889][11 00][00] v1.7.0.0 -> v1.6.0.0
[00013004][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013124][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013234][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013350][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013409][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013520][17 00][00] v0.0.0.0 -> v1.1.1.6 need upgrade.
[00013640][17 01][00] v0.0.0.0 -> v1.0.2.5 need upgrade.
[00013705][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013761][01 00][00] v1.14.3090 -> v1.14.3090
[00013822][01 01][00] v1.14.3090 -> v1.14.3090
[00013877]Done.
[00015931]Waiting for user confirm...
[00025984]Timeout, start upgrade automatically.
[00026095]Firmware upgrading[1]...
[00026173][17 00] Firmware upgrade start...
[00117260][17 00] Firmware upgrade finished successfully.
[00117329][17 01] Firmware upgrade start...
[00183185][17 01] Firmware upgrade finished successfully.
[00183240]Done.
[00183292]Version checking[2]...
[00183480][03 05][00] v34.2.0.9 -> v34.2.0.9
[00183580][03 06][00] v2.2.6.19 -> v2.2.6.8
[00183642][04 00][00] v1.40.0.0 -> v1.38.0.0
[00183715][09 00][00] v1.7.0.3 -> v1.7.0.3
[00183881][11 00][00] v1.7.0.0 -> v1.6.0.0
[00183995][12 00][00] v1.8.0.0 -> v1.8.0.0
[00184120][12 01][00] v1.8.0.0 -> v1.8.0.0
[00184230][12 02][00] v1.8.0.0 -> v1.8.0.0
[00184330][12 03][00] v1.8.0.0 -> v1.8.0.0
[00184394][15 00][00] v1.1.2.0 -> v1.1.2.0
[00184506][17 00][05] v1.1.1.6 -> v1.1.1.6
[00184665][17 01][05] v1.0.2.5 -> v1.0.2.5
[00184735][19 00][00] v1.0.8.96 -> v1.0.8.96
[00184790][01 00][00] v1.14.3090 -> v1.14.3090
[00184853][01 01][00] v1.14.3090 -> v1.14.3090
[00184906]Packet upgrade finish successfully.
[00012218]========== 2015.08.10 19:33:27. boot(5) ============
[00012276]Packet [C:\P3S_FW_V01.02.0008.bin] detected, card sn [0xa0ce32b3].
[00012340]Packet upgrade start...
[00012403]Packet checking...
[00012465]Done.
[00012522]Version checking[1]...
[00012624][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012729][03 06][00] v2.2.6.19 -> v2.2.6.8
[00012792][04 00][00] v1.40.0.0 -> v1.38.0.0
[00012870][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013005][11 00][00] v1.7.0.0 -> v1.6.0.0
[00013113][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013217][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013313][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013438][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013506][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013613][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013753][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013828][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013894][01 00][00] v1.14.3090 -> v1.14.3090
[00013952][01 01][00] v1.14.3090 -> v1.14.3090
[00014016]Packet upgrade cancelled at version checking.
[00012205]========== remo-con disconnect. boot(5) ============
[00012262]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0xa0ce32b3].
[00012321]Packet upgrade start...
[00012382]Packet checking...
[00012440]Done.
[00012496]Version checking[1]...
[00012606][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012786][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012852][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012924][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013066][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013180][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013299][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013425][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013535][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013596][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013689][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013849][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013924][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013983][01 00][00] v1.14.3090 -> v1.20.3419 need upgrade
[00014040][01 01][00] v1.14.3090 -> v1.20.3419 need upgrade
[00014098]Done.
[00016157]Waiting for user confirm...
[00026214]Timeout, start upgrade automatically.
[00026339]Firmware upgrading[1]...
[00039368][01 00] Firmware upgrade start...
[00011734][01 00] Firmware upgrade finished successfully.
[00011795]Done.
[00011854]Packet [C:\P3S_FW_V01.03.0020.bin] resumed, card sn [0xa0ce32b3].
[00011916]Packet vlink 01.03.0020 <-> 01.01.0009.
[00011978]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012035]Version checking[2]...
[00012156][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012256][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012321][04 00][00] v1.40.0.0 -> v1.40.0.0
[00012395][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012535][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012645][12 00][00] v1.8.0.0 -> v1.8.0.0
[00012744][12 01][00] v1.8.0.0 -> v1.8.0.0
[00012844][12 02][00] v1.8.0.0 -> v1.8.0.0
[00012944][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013009][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013120][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00013260][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00013335][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013398][01 00][05] v1.20.3419 -> v1.20.3419
[00013458][01 01][00] v1.14.3090 -> v1.20.3419 need upgrade
[00013515]Done.
[00013574]Firmware upgrading[2]...
[00013746][01 01] Firmware upgrade start...
[00044119][01 01] Firmware upgrade finished successfully.
[00044204][17 00] Firmware upgrade start...
[00170248][17 00] Firmware upgrade finished successfully.
[00170320][17 01] Firmware upgrade start...
[00242253][17 01] Firmware upgrade finished successfully.
[00242314]Done.
[00242379]Version checking[3]...
[00242470][03 05][00] v34.2.0.9 -> v34.2.0.9
[00242571][03 06][00] v2.2.6.19 -> v2.2.6.19
[00242637][04 00][00] v1.40.0.0 -> v1.40.0.0
[00242730][09 00][00] v1.7.0.3 -> v1.7.0.3
[00242870][11 00][00] v1.7.0.0 -> v1.7.0.0
[00242985][12 00][00] v1.8.0.0 -> v1.8.0.0
[00243110][12 01][00] v1.8.0.0 -> v1.8.0.0
[00243218][12 02][00] v1.8.0.0 -> v1.8.0.0
[00243343][12 03][00] v1.8.0.0 -> v1.8.0.0
[00243405][15 00][00] v1.1.2.0 -> v1.1.2.0
[00243518][17 00][05] v1.1.1.7 -> v1.1.1.7
[00243679][17 01][05] v1.0.2.7 -> v1.0.2.7
[00243790][19 00][00] v1.0.8.96 -> v1.0.8.96
[00243848][01 00][05] v1.20.3419 -> v1.20.3419
[00243908][01 01][05] v1.20.3419 -> v1.20.3419
[00243967]Packet upgrade finish successfully.
