Avata propeller fell off during the fly!!! Dangerous!!!
2149 10 2022-10-10
AFlying Penguin
Flight distance : 18373 ft
Hello guys, be careful of your avata!
So I was flying the Avata outside with the motion controller at low speed in full open space! The avata fell to the ground suddenly without any hitting or stupid flying action (I was just flying to the front, just accelerating nothing else!). Then I see this!
The propeller is just away but the nut is still on, so I guess the propeller failed into two pieces or what cause this!
My Avata is brand new, never dropped before, only 5km flying history!
Trying to get contact with DJI support but I am in Canada and they can't offer any support in my area, still waiting for their engineering to contact me!
I do have DJI care and I submitted the DJI care to get it replaced but I do feel this is an design issue or production malfunction. I do see in China lots of Avata user has the same issue!
2022-10-10
KLRSKIR
Flight distance : 28368625 ft
There seems to be a lot missing in this scenario, including a piece of the other prop on the right. I'd be curious to see the flight logs leading up to this accident.
2022-10-10
Nees
Flight distance : 80991 ft
Belgium
Dont replace it, put another prop on it and fly... It could be that the prop was on to tight and had a little crack
2022-10-10
AFlying Penguin
Nees Posted at 10-10 15:11
I can't take the nut off the motor.
2022-10-10
DJI Stephen
Hello there AFlying Penguin. I am sorry to read and to know about what happened to your DJI Avata and thank you for giving out these information. Since this unfortunate event happened, I would recommend for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do our best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you.
2022-10-10
deeve
Flight distance : 72864 ft
KLRSKIR Posted at 10-10 11:15
Good eye. Something happened to that other prop.  Maybe you unknowingly hit something. Branch or stick maybe.  Do you have the video from the goggles showing the last few seconds of flight?
2022-10-10
JAMh
Flight distance : 4754715 ft
Probably the prop was damaged in a previous fly/drop/landing.
With these props design, that the part close to the center is so narrow and thy are close to ground, you must check them almost before each fly.
If u feel/see any damage, change it immediately.
Don´t forget this FPV drone, not a Mavic
2022-10-11
Nees
Belgium
Oh i see, its screw broke off...  There are ways to get it out, but will be difficult without the right tools
2022-10-11
Bob Brown
Flight distance : 4209662 ft
I made the mistake of over-tightening the prop screws and had a similar issue. I would say when checking be sure they are "snug" but not "tight".
2022-10-11
djiuser_zQHbqJ5XZ6he
KLRSKIR Posted at 2022-10-10 11:15
There seems to be alot missing in this scenario? What do you mean by that? The other propeller likely cracked when the first one broke causing the drone to fall out of the sky. DJI made a poor choice using screws to attach the propellers. Snap in place click propellers have worked fine for nearly a decade, I don't understand why they chose for a clearly inferior design. Happened to me today during my second flight with my avata. It got three feet off the ground, the propeller spontaneously shattered under light load. The drone sustained several impact points of damage to the frame, battery and one other propeller. This was a horrible design choice on DJI's part.
2023-3-23
deeve Posted at 2022-10-10 20:14
2023-3-23
