BigTB
hallmark007 Posted at 10-25 09:44
Do you feel that evidence of a camera with a more properly focused lens means there are none with a problem?
So maybe point to the post where I said this, I can point to many posts to the contrary
It just seemed like a couple times someone insisted they had a problem, you were pointing out that video and saying it wrecked their argument and showed that there really wasn't a problem. If that wasn't your intent, I accept that.
All you did was enhance the lens, but if I go out and spend a 1000k on a lens it will be much more enhanced than the small lens on the A3, further if I put on a zoom lens I will be able to actually see more detail with my own eyes. The test makes no sense unless you’re trying to design a new lens. If I use the same diopter or range of diopters I can see improvements in all lenses, but the whole picture film takes on much different view. If you think you were creating some kind of more pleasing depth of field you failed you just turned up mush in different places of the frame.
I specifically said that the +4 destroyed the outer portion of the frame. The +2 diopter did not. I was not trying to create some kind of pleasing depth of field or anything like that. It also didn't crop in anything like the 4 to 1 you used as an example in my thread. I beileve the +2 diopter test shows that at distances of 2 feet or so, my Action 3's lens is not in sharp focus. That's all.
You seem to be contradicting your opening statement. I have been consistent in pointing out ridiculous tests that show nothing except they were bad tests that prove nothing, but certainly serve to create hysteria and bad information especially to beginners or first time users.
I agree that there may be some overly dramatic responses to this situation, but I think that goes for both sides. Hopefully you don't take anyting I say as an attack or accusation. Just intended as a friendly discussion.
No I am not and I posted that I also had a problem but after discussion with dji and changing a few things my camera is more than acceptable a much better all round camera than my A1 and equally as good as my A2
But it seems if you don’t agree with the “prawn sandwich brigade” or if you show what’s actually possible then you are a Liar, fanboy, work for dji, buffoon , amongst many of the names being called if you present anything other than the hysteria.
Incidentally at least I had the decency to reply to your threads it looks like most ignored them.
I'm glad you are satisfied with your camera, along with anyone else who is as well, including myself. I agree that it's a step up from the Action 1. My Action 3 has similar detail to my A1, but it has better stabilization, better battery life, better colors, and better audio. I do appreciate that you replied and gave your thoughts. And I agree that both sides seem to be getting intrenched in their positions and getting a bit aggressive. Lots of names have been called on both sides, which seems silly. Hopefully everyone can just agree to discuss, share info and opinions and learn to just let things go. This camera is a lot of money for some people, but even still, it's not worth stressing over.
