djiuser_LGn42cAxJIh5
Flight distance : 28458 ft
Ok so this is obviously been asked many times before already but I'm going to ask myself, I'm going to say straight off the bat the camera is absolutely phenomenal and the build quality is second to none but, pretty much everybody that has this camera is having the same issue which is things are out of focus, I've seen hundreds of posts about this but I have a different weigh in on it, I may be wrong but I think this issue is down to one of potentially to things, either the glass is too thick on the removable cover or the distance between the physical lens on the camera is either too close or too far away from the actual removable lens cover. But from what I've seen nobody has any footage of the osmo action 3 with an ND filter fitted instead of the standard glass, and I'm wondering if it makes a difference or not to everything being in focus, if it does then that is the issue, and DJI need to supply every customer with new lenses to compensate this major issue at no cost to us. |
