MarcoR
Flight distance : 316335 ft
The OA3 compared to other action cams by having a very wide FOV and perhaps low-fatness lenses suffers from focus problems on close subjects, this is a fact, imho it is useless now to keep posting evidence, it is very obvious, photography experts have ascertained this.
It is a fact, such as the Mini 3 Pro heats up like a boiler because in order to maintain the 249 grams of weight they removed the internal fan and if left stationary on for a while it almost bursts into flames.
These are indisputable evidences if one is capable of reasonable objectivity.
An action cam certainly was not born to take pictures, how a drone was not born to stay on for hours on a table, however vloggers often use OA3 with a stick to shoot themselves, and the wrinkles are clearly visible.
Instead, it is quite versatile for all the other uses for which it was created.
I think it is perhaps useless to continue to provide evidence, just own an OA2 and put them in direct comparison, the problem pops up immediately in the filmed subjects between 30 and 100 cm.
If the OA2 that has exactly the same FOV had the same problem its section on this forum would be full of posts about it, but it did not, it is not hard to understand why, even a child would understand it.
If this action cam has this insurmountable limitation it would be enough for DJI to offer the option for dissatisfied buyers to withdraw from the sales contract, perhaps by providing a spendable coupon on their site of the same amount.
This is because DJI has committed a flaw by declaring an unrealistic specification, "Focus range: 0.3 m to ∞", blatant lie.
Instead in the OA2 specifications the hyperfocal on the DJI site is not declared, check it yourself.
A GoPro HERO 6 has such hyperfocal distance and is verifiable, an OA3 does not.
The alternative for DJI would be to provide a replacement OA3 without this very obvious problem, changing lens system, udpate firmware (ridiculous and impossible route if the problem is hardware) or doing other things but solving the issue.
Let's keep this topic constructive. |
