JustName
Flight distance : 1420705 ft
I continued to fiddle with the lens setting last night, including turning the lens all the way out. In my case, the lens was attached with only two small glue drops.
My tests revealed the following: If you turn the lens too far out (CCW), the camera loses focus very quickly in the distance, but has a super focus close up, you could really use the camera for macro photography.
If you turn the lens too far in (CW), not only will the focus be lost at some point in the near distance (30cm), but the image will also become blurrier overall, even in the distance.
However, once you have found the perfect position, the image will be very sharp at 30cm as well as in the distance.
