DJI Paladin
Hi there. Thank you for reaching out. Kindly please refer to the information below with regard to your concern. Hope this helps. Thank you for your valued support.
Using the aircraft as the center
The remote controller icon turns green.
The remote controller orients at the aircraft, and the small dot turns green. At this point, the signal is the strongest.
The aircraft icon turns gray.
The aircraft has no GPS signals, or the aircraft is not connected to the remote controller.
The remote controller icon turns gray or disappears.
The mobile device has no GPS signals
The remote controller icon disappears, and the Home Point is at the center.
The mobile device has no GPS signals, but the Home Point is recorded.
The remote controller icon turns gray, and Home Point and aircraft icons disappear. The mobile device has no GPS signals, and the Home Point is not recorded. |
