Sean-bumble-bee
Flight distance : 15997 ft
Try a google for "dji mini 2 manual" you should find them easily enough on an official DJI site. You probably can print it, it's a PDF.
To stop a recording press the same button that you use to start a recording, there are two, one on the phone screen and the other on the controller either will do.
DJI do not include a "stop recording" function in the drone shut down process. Shutting the drone down before stopping the recording results in a corrupted file, this happens with every DJI drone that I have flown, Phantom 3, Mavic Mini, M2P/Z, Mini 2.
The solution is to switch the drone on again, let it boot and then switch it off, the drone fixes the corrupted fie during that process. It may be that that process DOES NOT work if the recording has been played with in the mean time.
I normally remember that I have forgotten to stop a recording JUST AFTER the shut down has been triggered and then I switch the drone on ....and off ....all whilst it is still in my hand. |
