Nees
Flight distance : 80991 ft
Belgium
rgp1942 Posted at 10-20 13:26
That's a good solution. Don't even bother to remove the SD card, just offload videos via USB. That's what I'll go with. I think I even already have one. Thanks!
its funny you find opening the cover, putting a cable with the props in the way easier then use your nail to push in the sd which pops out and take it out, the USB cable in the box is also "easy" to push in once you get used to it, but i use internal memory for now, but soon will have an extra sd, which will be a lot easier then any USB sollution |
