jimcloud74
Flight distance : 1298317 ft
Now. If we could only figure out how to brace the extremely fragile "arm" that holds all of this on the gimbal plate... I had a P2V+ fall from 9 meters and it all held together with a plastic setup just like this but gravity found the next weak spot in line. The arm bracket. This should probably be called a ribbon protector due to the fact that over about 1 meter you are going to have bigger problems than the ribbon cable. This is coming from someone that has "been there" and "done that". |
