Phantom circling... battery?
Zoyx
Flight distance : 8622 ft
New problem for me. I launched to about 6 feet high. My P3P started do a horizontal circle (orbit) that eventually grew to about 10 ft (3m) in diameter. It kept doing the circle, even when I rotated. This was after a compass calibration.
I noticed that the battery power was plummeting. I landed and during the minute or so of checking things, the battery power dropped another 3%. So I decided to swap out to the other battery. No issues with the other battery. I was able to fly up to 200 ft without any weird circles or orbits.
Why would a battery seem to be causing this? Did I catch it in discharge mode? Did the firmware update not take?
2015-8-11
Zoyx
Update:
Recharged the battery. Flew it in the same spot as I did before, no effect. Flew fine. Same calibration. Weird.
How does discharge mode work with these smart batteries? Is discharge mode supposed to stop when you plug it into your Phantom? Or only when you plug it into the charger?
2015-8-11
timswimm
DJI Team
Battery can't cause your drone circling. make sure you are in gps mode
2015-8-11
Zoyx
timswimm Posted at 2015-8-12 10:31
I was in GPS mode both times.
2015-8-11
timswimm
DJI Team
Zoyx Posted at 2015-8-12 10:36
oh, that's interesting ! anway it flies good, enjoy)
2015-8-11
Zoyx
timswimm Posted at 2015-8-12 10:39
I guess I am chalking it up to freak interference. The battery thing, was just a coincidence. Still curious if there are other theories out there.
2015-8-11
EpicDroner
Colombia
the "toilet bowl" effect is definitely a compass problem.  check IMU under "compass" to make sure its around 1400 to 1600, best is 1500 before taking off.
2015-8-12
