Mini 3 Pro error code 30064 unable to take off please help:(
1148 13 2022-10-23
Dji mini 3 pro
Flight distance : 797464 ft
Norway
My dji mini 3 pro isn't working unable to take off error code 30064 i have tried everything i can to fix it it won't work please i need a new beta software.
DJI please reach ou to me!
2022-10-23
DJI Diana
Flight distance : 2408 ft
Sorry for the having issues. Kindly check your PM. Thanks.
2022-10-23
user7daeb252a2
Flight distance : 4833415 ft
Brazil
Not working.  Sfagner804@gmail.com
2022-10-25
user7daeb252a2
Brazil
Mini 3 . 30064  familiasantos04@yahoo.com.br
2022-10-25
DJI Gamora
Hi, user7daeb252a2. We're sorry for the trouble this has caused and thank you for reaching out. I will forward this matter to the designated DJI department for us to be able to send your the firmware needed. Thank you.
2022-10-25
DJI Gamora
user7daeb252a2 Posted at 10-25 02:17
Hi, user7daeb252a2. Thank you for reaching out. I will forward this matter to the designated DJI department for us to be able to send your the firmware needed. Thank you.
2022-10-25
user7daeb252a2
Brazil
Muito obrigado.  Tudo voltou aí normal apos o update
2022-10-25
DJI Susan
user7daeb252a2 Posted at 10-25 22:36
You are welcome, and we are now having the official firmare released, you can also update the firmware to the official firmware directly.
2022-10-26
djiuser_2EmOTVfDHf32
DJI air 2S code 30064 please help. This happened after update. Was fine before
2022-11-25
DJI Susan
djiuser_2EmOTVfDHf32 Posted at 11-25 10:30
Hi there, it is because aircraft firmware V02.04.23.20 for Air 2S supports support for United States RID requirements. Please check and make sure that the App version needs to be updated to 1.7.8 or above. For mobile devices, it should allow the DJI Fly to obtain the location information and also needs to ensure that the DJI Fly app runs in the foreground.
See if the issue can be solved then, thank you.
2022-11-25
DJI Susan Posted at 11-25 17:41
Thanks I got it working after verifying that DJI app and aircraft were up to date. Thanks for responding right away.
2022-11-25
DJI Susan
djiuser_2EmOTVfDHf32 Posted at 11-25 18:10
Thank you for your confirmation, happy to hear that you have got it worked.
Should you have any further questions, please feel free to contact us at any time, we're glad to help.
2022-11-28
djiuser_WHdDcoDgonMM
I can't update firmware on drone
Mini 3 unable to take off code 30064, help?
2023-10-4
DJI Susan
djiuser_WHdDcoDgonMM Posted at 10-4 19:18
Hi there, sorry to hear about the issue you encountered. Just to double confirm, the firmware has not been updated for your drone and controller, and there is a 30064 error, right?
Please try to update the firmware successfully first and try again. Please try to use the DJI Assistant 2 (download link: https://www.dji.com/downloads/so ... sumer-drones-series) on the computer to do the update. If the update still fails, please provide a screenshot of the error message of the firmware update failure for better confirmation, thank you.
2023-10-4
