dcaton
Flight distance : 39606 ft
Not exactly what you're asking, but I have an Air 2 (not S) and a Mini 3. If I liked the Mini3 I had intended to sell my Air 2, but haven't done so yet.
I think the size/weight difference is a non-issue. Nobody is walking around with a Mini 3 in their pocket.
The big plus with the Mini 3 for me is the controller. It's just simpler to use a controller with a built-in screen. I have an iPad Mini 4 that I use with the Air 2 and while it works fine, it's another device to keep charged and fiddle with before you can get in the air. Battery life is also significantly better than the Air 2. And being able to charge the batteries with a USB C charger is better than having to drag around yet another proprietary power brick. Unfortunately the battery charger still suffers from the limitation of only charging one battery at a time, even if you have a high-powered charger. Poor design.
The one thing the Air 2 has that the Mini 3 doesn't is ADS-B aircraft detection. I never really found it very useful though.
I'll probably end up selling the Air 2 as I really haven't found a case where I'd rather use it vs the Mini 3, and I don't need two drones. |
