patiam
Flight distance : 1118740 ft
DJI flight planning/ground control apps are quite finicky regarding kml/kmz format import.
As LV-Forestry mentioned, one workaround is to export the kml/kmz directly from Google Earth rather than from a 3rd party GIS program such as QGIS or ArcGIS. There are also online shp to kml converters that will yield a file DJI will accept.
Another option is to edit the kml in a text editor and remove all but the most basic entries. You can use a kml you know DJI accepts as a template.
Good luck! |
